nice benches coolaler :D
now we want to see the merom extremely cooled :D
Thx coolaler for the benches !
Thats a seriously impressive mobil chip (or any cpu for that matter, but immagine that in a laptop). nice benches.
Originally Posted by kiwi
:confused:
This is what we all wanna know :)
performance test 6.0
http://edu.tchsien.com/CBB/coolaler/merom/9.gif
it's problem:DQuote:
Check the name.;)Quote:
Originally Posted by coolaler
http://img329.imageshack.us/img329/9...03065bw.th.jpg
YES!Quote:
Originally Posted by dogsx2
+1 :)Quote:
7600GT out,7900GTX in (NO MOD):woot:
3DMark01 999fps again :D futuremark
http://edu.tchsien.com/CBB/coolaler/merom/4.JPG
http://edu.tchsien.com/CBB/coolaler/merom/3d01_1.gif
Omigosh, thanks for posting...
hohoho!:banana:
3DMark03
http://edu.tchsien.com/CBB/coolaler/merom/3d03_1.gif
Wow man, that is awesome, keep up the good work.
... and this is the MOBILE chip! wooohoo!
Frick this's awsome...I was all excited to get the rig in my sig and start upgrading...but it looks like I'll be waiting to pickup one of these beauties. :D
Thx for all the benchies coolaler...nice not to have to ask for them for a change. :)
so what's the go with FSB wall? :p:
Man I knew these things would be kiler (amd wise)
But there kiling the previous amd kiler by far (conroe)
Also thanks for the benchies, it is kewl not to have to ask for them, your just smashing them outta the park bro, impressive, the 7900 ownage is nice to see too..
Cant wait till mine gets here, ur 03 is awesome 7900 single card right? or SLI?
Bingo! Lower wattage, easier to cool (technically, less heat to remove). Do we have overclock wattage scaling numbers on these? (I need under 80W max when overvolted and overclocked :D ).Quote:
Originally Posted by railer
And may I assume that these Meroms are plug-and-play into the AOpen i975Xa-YDG (i.e., no bios upgrade needed?). :confused:
Great work Coolaler :toast:
conroe and merom are the same thing.....one is desktop and other mobile......the results should be the same between the two or very very similarQuote:
Originally Posted by Philosophy
damn nice 3d05 for single card with those clocks.
Xtreme mhz \ speed ratio .
its SLI..Quote:
Originally Posted by lowfat
come on coolaler, give the merom some - degrees! :D
is this all on the passive cooling in the pic? or did ya use a fan on it after?
