Many thanks ! :)Quote:
Big_Sam, what chipsetdrivers do you use ?
I'm on my way to find out this little 'mod', I get the SLI-tab, but no checkbox to enable sli :(
First I tried on OS istalled since P5WD2 (i955X) :) , then tried chipsetdrivers from original disk which was together with P5WD2-E (I do not remember number of the version) . In both cases result identical.Quote:
Originally Posted by massman
Ygpm
Nice work, Big_Sam ... :toast: :clap:
43000+ in 03 without ANY serious GraphicsOC and with "middle end" CPU (forgive me, but I think that some 955/965XE will perform much better:D ) ... that`s :eek:
I imagine what score you`ll get if you`ll get some 6GHz (or at least 5.5) Intel CPU and crank the GPUs to 900-1000MHz :rolleyes:
P.S. It would be really nice to see 05 & 06 scores (if it`s possible) ;)
P.P.S. It`s bad that you don`t share modded ForceWare... Do you know how many people (for example, me ;) ) have an Intel Mobo and want to go SLI but for the drivers... :D (I know that it`s hard work to hack the drivers and you don`t want to give them away "for free":D )
drivers are NDA ;)
Well, I'm trying to get the SLI working, yet it won't start :@
where's the checkbox ??
@easypanic, thanks for quick test.
Well, checkbox isn't there. Somebody with working SLI on any platform should check if the SLI is enabled in registry. You could use a regshot v1.72 to find out what and where the entry is changed by simply unchecking SLI, dumping reg image, checking SLI back, dumping reg image and finally compare them.Quote:
I don't get it, if you and Sam have that driver or reg entry why not share them to XS members?Quote:
...and please don't ask me for a copy.......
Because it's NDA. It's not my place to be freely handing out the result of someone else's hard work without their permission........The reason I posted here was to confirm Big Sam's work with this driver, that's all.Quote:
Originally Posted by need.for.mhz
Would it be fair to say that these drivers will be released by Nvidia on or around the same time as conroe?
Or is the NDA with some other company?
Mav
and Ati chipsets as well it seems ( check out Coolaler thread in Intel section ).Quote:
Originally Posted by Sneaky
Nice improvment in score Sam :toast: great GT1 score.
Regards
Andy
Thanks :)Quote:
Originally Posted by zakelwe
New result with delta of GPU blocks equal 0 : http://service.futuremark.com/compare?2k3=4768037
Frequencies - 740 / 935 Mhz, no volt mod.
Some results here with T2600ES@3303 and SLI 7900GTX ~700/900
http://www.thelab.gr/attachment.php?s=&postid=384123
http://service.futuremark.com/compare?2k3=4768603
8443 is not approved yet
I get ~ the same score with an 955XE @4.6 on air..:D
2005 here
http://www.thelab.gr/attachment.php?s=&postid=384125
only mhz and nothing more...:D
http://service.futuremark.com/compare?3dm05=1992736
I'm certain that my regestry is ok, so I'll try a format later on the dayQuote:
I think that the some people will agree with me, SLi on intel - something is remarkable in it. :DQuote:
Originally Posted by GoriLLakoS
Hehe...yes...for sure..:D
Any news?Quote:
Originally Posted by maverik-sg1
Mav
no, drivers are still NDA.
Some people have those drivers, some people modded reg correctly, but SLI won't work (:D).
Just wait 'till the drivers are official
But I have no patience :D
Well, I found some regtweaks, see it in the attachment.
But how come temperature monitoring is suddenly gone???
It would be really nice, If those drivers/tweak would become somewhat available to ordinary people, like me for eg., cause it seem a lot of people here got their hands on them and it just isn't an exclusive anymore.
same results ... :(Quote:
Guys, these reg keys wouldn't work. I know.
Ok.
Fine.
Any suggestions then??
I know the person who did it... Turns on SLi by editing the register. His nick is - defecator ( http://www.xtremesystems.org/forums/member.php?u=27193 ) It's not a joke, I saw screens with results.Quote:
Originally Posted by easypanic
Several months ago I communicated with him on this theme, but I did not have not enough time to understand it...
