Originally Posted by Repoman
I'm halfway thinking of picking a coulpe more up, just to hold onto for a while, the 0550s sold for insanly high prices on ebay. $500+ Could probally recoup my whole cost of the chip.
Repo,
Do you think, a single PA 120, DD D5 and a Storm rev 2 would be good enough for this processor. I really dont want to bother WCing my video card and I would like to avoid modifing my case.
I'm no WC expert, just got this set up a couple weeks ago, but right off the bat I can tell you instead of the D5 you should get the Aquaextreme 50z from cooltechnica.. less heat dump, quiet, and near the same head pressure.. And for CPU, an aqx MP-05 according to a guy in the wc forum should be equal to storm rev2 for $20 less.. I have one and it's pretty nice.
Also I think a PA160 would be better for the rad
Originally Posted by Spazilton
you'll want at least a double rad setup...i wouldn't recommend a D5 (too much heat dump), get a DDC + (make sure its the PLUS model) and either mode it or get a new Alphacool head to get 1/2" barbs all the way around..with your setup (especially your 1000W PSU!!!), surprised your not going to Phase! ;)
So whats the verdict! Show us 3.0GHz on the DFI! ;)
Guys, the heat dump from the D5 isn't noticable. I have run both AquaXtreme50Z and the D5, both are great pumps and performance is virtually identical.
My old loop
Storm G4, D5, 120.2 heatercore
new loop
TDX, 50Z, 120.2 heatercore
Old loop was about 1.2c better temps all around, mostly due to the block. I think the D5 is a superior pump, it dumps a little more heat but it's hardly noticable, water has a huge heat capacity... D5 is more powerful. If you're going to use a lot of blocks or do a dual radiator setup, D5 is recommended. 50Z will suit you just fine otherwise.
Would it be ok to run 2 single 120mm rads? The only place I could mount a double rad setup in my case would be on the top, and with how the Lian Li case is setup, It would cause conflicts between my second video card and the Rad.Quote:
Originally Posted by ST4
I could mount a PA 120 in the front and back of the case with little problems.
A PA160 will perform close to a double rad with enough (80cfm) airflow. If you could fit 160mm in your case then you could do that.. (only takes 120mm fan btw).
It would have to go in the front of the case and exhaust onto the hard drives. Don't really like that Idea they are enough of a pain to keep cool as is. I dont think their would be enough clearance for the 160 in the rear. I guess I need to do some measurements to double check.
you could always get a radbox and throw the double or even triple rads in the rear if you're okay doing it externally. you know the bip 3 is going for $30 bux right now too..Quote:
btw> DDC+ is equivalent to D5 on setting 4 i believe, and quieter with less heat dump...
You know thats actually a pretty good Idea. Hadnet thought of that, with the rad box handle a 120x3 Setup?Quote:
Looks like the 0610DPMW are gonna scale pretty well too.. mine ended up at 2844 on stock volts, priming at 2934 with 1.4v. I'll be really happy if this is stable, that's nearly 100MHz for .05v :eek: usually takes around .1v/100MHz
http://img135.imageshack.us/img135/7...41350vv.th.jpg
Too impatient to wait for longer primes..
http://www.swva.net/jehamilt/repo.jpg
Rehosted the pic for ya, I hate Imagespace's popups.
Hey man, thanks :)
yeah imageshack's popups are the one thing firefox adblock can't get, because you will end up blocking all images on the site :mad:
yes, it doesn't matter how rads it is, you would setup the rad in the middle fan and you'd be set. this is the same configuration i was potentially going after!Quote:
btw> 0610 do look strong. seems amd is cranking out some nice CPUs lately!!
Yea kinda hard to pass up $30 for a 120x3 Rad. If I could combine it with the radbox, they I dont see why I couldnt watercool this case.Quote:
There is somebody at AnandTech who has a 165 that does 3GHz at stock volts on air cooling. I'm not going to search for the thread though.Quote:
^That's awesome!
Speaking of 3GHz, got bored of low voltage and I'm going to see what's the lowest volts I can do there. Priming a couple mins now at 1.475..
Sounds like the next 0608MPMW
I'm 99% sure these are coldbugged, if your results are indicative of all of them.
Are you guys still running the 0610 with the IHS on? :D :D
There's 4 people on AT that has 3GHz chips that I am aware of: Lopri, Elfear, Absolute, and myself....none of them are on stock volts....Quote:
Originally Posted by 003
yeah little skeptical about stock volts myself, i need 1.4v on water for 3. Even my 170 with the IHS removed needs 1.39 vor 3 Ghz. 3 on air with stock 1.35v - possible to get there but dual prime stable in normal ambients is doubtful.
I clearly remember the thread, I just can't find it anymore. it wasn't a big time poster, it was just somebody who registered for the sole purpose of posting their results. I don't know if he was lying, or if it was photoshopped, but I do remember it.Quote:
Ah I think I remember that, don't know whether it was on anandtech or not. It was some whiny guy that wanted everyone to recognize his crappy OC, everyone said it sucked and he comes back with 3GHz at stock voltage.. I think he photoshopped it
Im doing my history work now, wont be done till around 10PM then I get to play with the Expert.
I curious to see if you can get 3Ghz out of it :)
was it one of these threads?Quote:
http://forums.anandtech.com/messagev...&enterthread=y
sorry for the OT....just waiting on further results of 0610...might have to test some myself! ;)
