Spiders bad... hehe
Spiders bad... hehe
And scary. :eek:Quote:
Originally Posted by arisythila
lol,
Nick
Got my card running a few days ago. My stock cooler load temps were ~90C. Now using custon water cooling 47C max. That is more than 40C less!
But I don't get this strange way of oc of x1900 series, why 4 voltages and why the hell does it freeze when I up frequency using latest ati tool :slapass: I am sick of this freezing. Maybe I should not use artifact scanner. I've oc so many cards but here I am feeling like complete noob :D
Originally Posted by kiwi
I just maxed CCC at 690/800, stock volts and on water I dont break 37c.
A few more fps aint gonna matter. I would love to see a max CCC oC'd X1900XTX face off against a stock 7900GTX though.
I'm finding it hard to believe the 900 worked that well for you after reading all the other horror stories about them on other 1900's. I have two new 900's just sitting in a box waiting to be returned because of how badly it performed compared to the stock cooler at 100%....
there is no way in hell just by changing the TIM would drop 20'C!! I'd replaced mine with AS5 as soon as I got the card, only dropped about ~4'C, remounted the heatsink no less than 5 times with same result, even tried to mount the X2 heatsink on this sucker with not much improvement, loading temperature (ATITOOL Artifact scanner) always in the 80'C~90'C depends on ambient, like dnottis I'd also broke down and went water cooling for the entire system, now the X1900XTX is running 740/860 1.55/2.20/2.20/1.56 it idle at 35'C and underload around 41'C.
WHAT? You are using Rivaturner? Is there a new version for the x190xt/xtx because mine will not show temps...Quote:
