Very nice job PcCI2iminal
CPU :Intel Core Duo T2500
M/B :AOPEN i975Xa-YDG
MEM :Corsair Value 512X2 Dual Channel
HDD :Hitachi ATA100 40gb
VGA :7900GTX 720/1970
POWER:ZIPPY Type r 600W
OS :WIN XP SP2
CPU COOLER:water chiller
http://img104.imageshack.us/img104/4...7900gtx8gy.jpg
http://img104.imageshack.us/img104/4...7900gtx9nm.jpg
http://img104.imageshack.us/img104/9...7900gtx9ov.jpg
http://img104.imageshack.us/img104/1...7900gtx4ck.jpg
http://img104.imageshack.us/img104/2...h3060pi8nw.jpg
im trying bios or remote but only fsb @ 255
I always bought parts at the Sofmap there in Hiroshema! What store did you buy them at? :)Quote:
Originally Posted by PcCI2iminal
omigosh! rockin....
one of them mobos is mine :D
Aopen will be in good hands and i can`t wait to c how good is your chip :DQuote:
Originally Posted by ibby
are you from Hiroshima?Sofmap is a good n a bit expensive store but we can find anything there :DQuote:
those Aopen are from Arc Japan Nagoya
1.504v :eek: got mb mod?
really great job:clap:
no mods just coolingQuote:
Originally Posted by kingkong
and the funny thing is about bios ,cpu temps @ 0C degrees and pressing "del" to set bios i just get a black screen :eek:
but no problem when i go straight to Windows.
one board is mine:D :toast: :banana: :woot:
and one is mine! :D
good job man!;)
:D I'm not that big, just a little strong:D :DQuote:
Originally Posted by GoriLLakoS
my D9 works fine on i975Xa, but i still can't solve the problem!:D :D
:D i am really a heQuote:
Originally Posted by Willis
if a she called Kong Kong........:nono:
:D shhssQuote:
Originally Posted by vengance_01
and one is mine!
good job man!
Yes, but the faster one is mine.;) Thanks PcC12.:D
How do you get crossfire to work?
If I have two cards in mine, once in install the drivers and reboot I get no signal to monitor in windows.
Any ideas?
nice benchies dude :toast:
Originally Posted by wwwww
hello there
its easy
go to safe mode and
http://img155.imageshack.us/img155/8...sfireon9jc.jpg
reboot and enjoy the power
good fix :D
ill write that down foe now ;)
sorry about the japanese version
:D
i can translate it ;)Quote:
Its simple
1) put the tick in the box
2) click apply :D
thanks, will try
lolQuote:
:DQuote:
Just make sure you boot into safe mode :D
Actually I think it was take the tick out of the box - 'cause that worked perfectly! :DQuote:
post your CF score and rig
:D
Just did a quick 01.Quote:
Only 37k so I didn't upload.
2500 @ 2.64GHz
mem @ 293 3-3-2-4
1900 CF @ stock
ppl on OCAU asking of pc05 so doing that
:D
I was close sir !
