never had a set sadly. i'm gonna be testing both of the teamgroup micron sets i have in it again though.. there's a new data drive strength that i think may help the new set :toast:Quote:
Wow, I was eyeing the new Venus bios yesterday and was wondering what this new temp calibration option was. Very cool that DFI would include it in its older boards for us. I thought we would no longer see new options for the Ultra-D. I love how we get latest memtest and NVraid rom too. Very cool. I am going to flash this in a bit and see how it fares over 11/14 which is working very, very well for me right now.
At first they wouldn't both boot(oranges). Now i fail memtest with this bios.Quote:
I had to look up whether this goes for the SLI-DR, too. Why don't they list the supported models on the webpage for the BIOS download?
Anyway:
Looks "non-intelligent", aka just adds the value.Quote:
Date Code 2006/03/29
Major Reasons of Change:
1 . Add CPU temperature calibration option.
This is the most interesting one. Is that an overvolting safeguard?Quote:
4 . Fix startup VID option fail.
Who-ho! I really missed this. For my TCCD I often go way above 320. Pretty annoying when you come from 200.Quote:
9 . Change FSB option to keyIn method.
4 Dimms better supported I assume.Quote:
13 . Synchronize DRAM related code with Expert and Venus.
Have to wait for a SLI-DR version to appear but I'm eager to try.
Too bad I sold all my BH-5.
Every "early" nf4 board bios to date has supported all the boards, ultra-d, sli-d/dr.. why would they change it? I'm sure it will work, give it a try, if anything it just will detect as nf4 ultra chipset
Huh? This bios is for ulta-d and sli-dr versions. :stick:Quote:
Originally Posted by uOpt
I would assume the same but it is not what they say.Quote:
Originally Posted by xgman
Here is the BIOS selection for the SLI-DR:
http://us.dfi.com.tw/Support/Downloa...FLAG=A&SITE=US
I don't feel like trying to flash the wrong BIOS.
Bios is in my SLI-DR atm... :stick:
hmmm, my cronus micron sticks definitly seem to like data drive level 4, helps an extra mhz or two. using any of the >1:1 ratios seriously kills any overclocking though:nono:
Eboy is running this bios with 2gb crucials too more stabil then ever now.Quote:
Originally Posted by eBoy0
I did run into a problem with the same settings as 623 bios it wont even boot without BSOD.
Found the problem here this bios dont like drivestrenght 7 but does like 5:fact:
Works memtest stabil now @ 300mhz 3-3-3-8
Good luck:toast:
I cleared cmos, but gave your tip a try... 288 errors in 1 loops compared to 0 before...:mad:Quote:
Grrr back to no post 1 led.. going back to 7/04.
Seems pretty good, gonna give it a try once my 7900gt arrives and I can put together my system.
me tooQuote:
Originally Posted by ChkDsk
Love this bios to dead:fact:
http://img328.imageshack.us/img328/7...lsprime8wt.jpg
really nice clock on the ballistixQuote:
is it your 24/7 setup ? (2.87v is kinda high)
Its indeed my 24/7 setup 2,87v isn't that high i think.Quote:
Originally Posted by Supertim0r
I have a 120mm fan over them.
I have running them since 17/01/2006 @ 2,87v and still going strong.:fact:
I stopt priming after 2 hours.
I will try higher:cool: later.
Man... At multi x10 with Opteron 146 there is no longer an option to choose div150 :( I need it...
I can choose it from A64Tweaker, though. But it would be nice to have it back in BIOS, pleeeeaaaseee :fact:
Was it there before Bachus? It is normal to not have it on certain Multi'sQuote:
Originally Posted by bachus_anonym
Yes, it was there in 6/23 - as this is the BIOS revision that I've used since it was released. I have also now flashed to 11/14 and it's there as well...Quote:
Originally Posted by RyderOCZ
EDIT: It's also not there in 7/04... Hmmm, I wonder why...?
Weird, I've only used 704 and this new one and both have all dividers..Quote:
Hey ryder, you mind checking the overvolt out? If it's only my particular mobo?
The only that overvolts on my ultra-d is the vcore, usually around .04-.05, read with dmm.
Everything else is like a rock.
So far this bios is working great for me. Was using 6/23 and couldn't get any divider except 100 stable with a 144 opty. Just completed 32m 9x328 with 140 divider :woot: Starting prime now.
http://img129.imageshack.us/img129/4...832m3iy.th.jpg
What did you set your vdimm to in bios? 2.76 seems like a weird number.Quote:
Originally Posted by 4X4N
