pray to the gods :D
http://service.futuremark.com/compare?3dm05=1915314
i need some cpu power to get 8k :p , but that will come .
its not done yet , hope to get a dice tube from jort and put cpu on nf3 and run it like hell :D
pray to the gods :D
blind_ripper
no link... you have 16 pip!?
to all
By the way installation of radiators for memory though has helped someone?
check my 8k thread , nope simpel x800pro 12pp :DQuote:
Originally Posted by Nordling
blind_ripper
http://www.nordling.jino.ru/forum/images/smilies/v.gif
It is necessary to me to increase my advantage ! I Think 8¬ will type not difficultly, ice I shall go to freeze... http://www.nordling.jino.ru/forum/im...ilies/jkjk.gif
remeber i have 500mhz cpu speed left , and dice tubes are on ther way :D
blind_ripper
Nothing has understood... Write easier!
sorry my english sucks , i have 500mhz cpu power left in my cpu . so if u want to get me hurry up . jort has lent me a gfx dice tube :D , and i will have willes his dice tube to :D
blind_ripper
bat sorry my english sucks too http://www.nordling.jino.ru/forum/im...ies/dfgdfg.gif
In any case I shall tear any your result! And under system of phase transition on GPU and CPU especially though now ice water I shall use... http://www.nordling.jino.ru/forum/im...ies/fghfgh.gif
gpu is only phase , but its not holding the x800pro @ 2.07vgpu :D .
cpu on phase on a dfi can do 3.1ghz easy ;)
blind_ripper
lol... But I can use record frequencies in a mode 24\7
in ORB was section GTO hurrah! I shall necessarily type 8000 the nearest 3-4 days! Tomorrow meal behind a dry ice! I can't stop =)
http://service.futuremark.com/compare?3dm05=2005509
3DMark Score: 7789
CPU Score: 5809
see that u tweak ure bench first m8 ;) i have 8k with less clocks :D
blind_ripper
ORB plz... 12 pipe?
here u go yes its 12pp , ant no im not gone give u a hit on those tweaks .
there are no lods , these suck in 05 ;)
http://service.futuremark.com/compare?3dm05=1922909
blind_ripper
Whot tvic you use? LOD (namber)?
no lods ;) pure windows , and some drivers , these are leagil for sure . point is no wanne seeks themQuote:
blind_ripper
Me strongly guards your actions … Much not clearly for example: Non WHQL - Not FM Approved! Here all is obvious not purely!
if u look good that are omega drivers so thats why greeds , if i have a other ati card il bench the same tweaks on it on officel driversQuote:
link plz...Quote:
omega drivers
look at the compare m8 im not gone fool u , think benching is al bout clocks then u are wrong very wrong .Quote:
lods are some times good but in this case get them the hell out of there.
No tnic system and draiver's (6,2) - http://service.futuremark.com/compare?3dm05=2007894
Nice score ! :toast: :)Quote:
nice but still 100mark short of the 8k , ure gfx clocks are very much higher than myn . didt dice and killed my card , now waiting on the 7900GTX to come here ;)Quote:
Hehe I like these competitions! They are entertaining to watch. Both of you are very determined to win against one and another, it reminds me of Rocky and his opponent from Russia, Balboa and Drago :P
-k0nsl
Whot core MAX for r480 in WR? i can use r480 >800 (3d and mark's) bat i need more time...
