my theory is that if your on air the N chip will suit you more. I belive N chips run higher on less voltage. I also believe that when you hit a wall with the N chip on voltage it takes alot of volts to go higher. It is at this point where I see most premature N chip deaths. These tend to like very fine .01 to .025 voltage bumps. These also do well on phase if you want to run near stock volts at very high clocks. Great for a 24/7 rig.
And yes It's opposite with T chips i believe. Those are far suited better on very very high end water and phase. They tend to need more volts and larger voltage bumps etc instead of .01 to .025 they usually need .05 bumps to get to the next level and tend to be more resilient with high voltage. I have seen these die most when people try to burn in and run them at low volts.
