Originally Posted by Monge
Sorry I don`t cause I always run the fans @7V...I will try to test them when I get the D5...I will dismount the WC than ;)
Regards,
Primoz
Regards,
Primoz
Thanks :)Quote:
Originally Posted by Primoz78
I think the Scythe S-FLEX SFF21F@7v perform more or less like a Yate Loon D12SL-12 @1000 RPM approx. 37-40CFM
Just to give an idea.
Cheers Monge
The Yate loons are not availabe in my country :( ...so the Schyte was the best I can found here...thinking of the power/silent ratio...Quote:
...I`m just thinking about...if it will be worth to put this 2 more fans on push...:cool:
Regards,
Primoz
Woulda been nice to throw the Bonneville heatercore in there just to see how it stacked up.
The Schyte 's are very nice fans regarding performce/noise, indeed :)Quote:
I was just trying to figure out how many CFM's you throwed at the Cooltek.
If it's worth to put 2 more fans in push/pull are difficult to say. You'll have more noise for sure. But why don't you try.
Cheers Monge
Not so big difference in noise I think...cause the dba is not counting like 10+10=20dba...as I know...will see...or better will hear :)
Regards,
Primoz
For every 3 DB increase = double the noise.
You might go to http://www.silentpcreview.com/files/...s/fanspecs.pdf and check.
But who cares. Test yourself :D
Cheers Monge :toast:
Thanks for this ;) ...I will have the fans on 7V so the noise should not be the problem...I hope :cool:
Regards,
Primoz
Another question...this time about tubing. I have now 12mm (inside) tubing on my WC setup...I have found some 13mm (also inside) and I want to put them on my WC...the pump is D5 and Cooltek extreem dual rad...is 13mm tubing too much for this?
Regards,
Primoz
You be fine with 12mm (inside) tubing or Masterkleer 7/16"Quote:
Look here:
http://xtremesystems.org/forums/show...99&postcount=2
http://xtremesystems.org/forums/showthread.php?t=94898
Cheers Monge
