what samurize config is that? its sexy.
*shrug* just a custom one, white meters on translucent black... i switch backgrounds often, and anyway i dislike bling - i run bblean instead of explorer for a window manager and total commander as a file manager, no taskbar, no desktop icons... just a small systray and 2 samurize configs.
Creidiki, I can tell you where to measure the vcore so long as you can get me a high resolution picture of your mobo around the CPU socket. You would need to remove ur Storm and stock mounting bracket though.
Hmk. Ill do that if I decide its worth popping the lid off :)
were those load temps on the cpu? 39C is very good
My load temps are like 42c.
I was getting 39c on my naked FX-53 :P
damn..I wish I could get my load temps close to that...
Well, what do you know. I had totally forgotten to add AS5 in between the CPU and Storm. 39c load. Reckon she'll do 35 if i pop the cap off.
FCX1800 temps a little high, but thats because im being a :banana::banana::banana::banana::banana: and not tightening the screws XD
I need to have a chat with eddy about how much pressure is acceptable for the screws round the cpu core.
a surprising amount actaully.. dont know about the other components, but the GPU can take alot of mounting pressure. its most likely due to the fact that they are HUGE.Quote:
Originally Posted by creidiki
Right right, but as you might imagine im a little paranoid, given what happened sunday night ;)
hey! i did my loop rebuild but sadly no chipforce cooler! :( it was out of stock EVERYWHERE i checked SIGH. i wantssssssss itttttttttt
Sorry for the off topic but, mind sharing your samurize config? it looks awesome!Quote:
Thanks in advance.
Sure, just pm me your email.
