and presumably starting at 50kohm resistence and working down?
and sorry but i don't have a vddci picture.
the picture i just posted came from Angelz at XR (thanks Angelz)
Originally Posted by Waxman
You're welcome.......
The mod will help ONLY if your VGA can handle more than 1.575VCore......Test it and see......;)
Yes........:)Quote:
Originally Posted by flytek
Why would it not handle if you have good cooling? :DQuote:
Originally Posted by hipro5
Especially if yours works at 1.76V :D
George we need a better score. we need to push everything to the absolute limit. you where gone when i arrived @ the lab today. how was the evap temp when ati tool showed -83?
im checking if i can get more LN2 friday. (damn we need smth like a 300lt dewar)
lol I'd like to see your lab where a bunch of clockers are benching, modding, partying etc :D :p:
I don't think H<sub>2</sub>O would benefit from more than 1.575V the max ATI Tool provides but I suppose there might be a few cards that can handle it.
Thanks again hipro & congrats on the first 1Ghz benchable ATI core :toast:
-98*C.........Quote:
Originally Posted by esdee
Originally Posted by G H Z
Thanks M8.......I'll try for more though coz Vince(k|ngp|n) is "preparing" his rig too....... :D
hipro5, if I understand this good, u are only putting Vcore up so gpu gets hotter and u are no longer in bug zone, or just less.
Right. Those are 'just' hardmods for more voltage (and heat), or did I mis something here? :s
It's really no different than the special BIOS'es that were run @ Ibezia on X1800's that fired up with 1.4v default before entering 3D mode, just that hipro's version is hard and allows higher voltages overall.
Well all the extra voltage gives it more power/stability and it is able to handle the cold. It also causes the core to put out more heat wattage etc.Quote:
Originally Posted by wittekakker
Amazing work hipro! I will not be surprised when you hit 60k, and I know you will! :clap:
VCore mod helps as for the subzero temps........BUT VDDCI helps a lot better for it.......I think that it is the Internal's Memory Controler Voltage......;)
PLUS there is also memory controler's (I believe that it's memory contoler's voltage the VDDCI as for it's behavior) voltage that helps too......;)Quote:
Thing is that you cannot find any dataseets as for the main voltage control unit(VT1103) coz I could do a lot more than that......Confidential my a(h)ss........:slapass:
Thanks M8.......BUT 60k are too difficult to be done with this setup.....Maybe with Yonah.......;)Quote:
Originally Posted by bigval
heres a pic of the other to mod hope the pic is good enough it'a a little greasy on the card just run LN2 on it..[IMG]http://img213.imageshack.us/img213/5...asy10ka.th.jpg[/IMG]
Dam i did the mod today and my card is now dead...... When i start it shoves 0,01v too the core ..... took of the mods but still the same :(
Somthing went wrong :(
No datasheet, that sucks man :( Nice find from you. :toast:Quote:
So...the thing is u still have to get a decent card. If it cold bugs around -30°C u aint going to break any records :(
But hey, ATI cards can again be puched a little further now, that's always something good to hear :)
MickeyMouse slave is also dead after the mod :(Quote:
Originally Posted by Overklokk
0,01V to the core, looks like the power circuit has had it. Or you pc is not booting.
thats sucks Overklokk:( , wonder whats failure with youre mods
I would guess that the problem is probably the ammount of heat which was used to solder to the Vgpu resistor. The resistor would be very easy to kill with too much heat, considering its size. I've done it myself, and its very easily done :(
Edit: Great work on the mods, Hipro :)
i hope thate the mod dos not kill more cards thate it helps to kille the cold bug :) , my is on is way to jort , hes gone mod it and thene il put it onder mach2 ;) cold with ccc whase -12°c
Could u resolve your problem by replacing it?Quote:
Originally Posted by persivore
hmmm. maybe we just need a bit of bios editing then
