Unfortunately the Newegg reviews for antec neohe arent so great :(
http://www.newegg.com/Product/Custra...82E16817103941
Most of them are talking about old NeoPower, not NeoHE series.Quote:
Originally Posted by perkam
The original NeoPowers are made by Antec, these are made by Seasonic ;)
I know The Antec NeoPower was the greatest Antec PSU ever..:fact:Quote:
Originally Posted by The Stilt
as for the NeoHE.. the qualtiy control on them is far less and they are made for cheap upgraders.. and considering the fact how freaking light they are.. I don't trust them and niethier should anyone else..:fact:
Higher efficiency = less cooling needed = less weight.Quote:
Originally Posted by nn_step
Have you ever tried to run SLI or CrossFire setup with Antec NeoPower?
Fortron is definitely one of the best power supply manufacturers in the world...
Do you know how much does Fortron Epsilon 700W psu weight? It it also pretty light since it has pretty high efficiency ;)
By high effieciency you mean low redundancy and bad tolerances.. which is unacceptable..
Antec 550 dead on action here with only single 6800Ultra and FX55 overclocked to the hilt:(
Nooo...Don't even put Antec Neo near SLI/CF rig:)
lol.. Oi.. I am sorta glad I didn't go dual core.. I'm likely stressing my quad rail silverstone out as is...
People still use Antecs? When Compusa starts selling them, it made me think twice.
Yeah.. they are good for the price.. they aren't PCP&C but they are acceptable for what is demanded of themQuote:
Originally Posted by situman
That is certainly the case.Quote:
Originally Posted by Dumo
I need to power a Supermicro H8QC8 with 4x875. It works fine with my single-rail OCZ 520W. But of course I won't do 8-core prime at full power with that PSU. To actually run with the 520W I downclock and undervolt the CPUs.
So I ordered a custom build of PCP&C 1 KW (I need two native 8-pin EPS12V). Apart from them first sending a wrong build, the replacement does not power up the above board. Tech support figured I overload one of the 12V rails (it has 3) on powerup and shrugged, giving me a refund.
I now ordered an Athena 850W, which has 48 A on the 12V, and a switch to put the 12V on one or two rails.
And yes, I will burn it in for a week before trusting my Supermicro with it...
P.S. I tried some of my socket 939 overclocks with the PCP&C 1 KW. Compared to the OCZ 520W there was no gain.
nn_step, post edited :) Pls take a look at who you're talking to before making claims of bs.Quote:
Antec has a long way to go in proving people that it is up to par with PCP&C, OCZ, Zippy and Seasonic. Enermax is doing it as we speak.
Check out the Enermax 500W Liberty review in the Xtreme Reviews. That thread alone has been the cause of the popularity of the Enermax 500/620W liberty at XS and the reason Enermax rep joined up to answer some of our questions...they've started to come around :) And Antec will need to do so again, i wouldn't mind if they used some snazzier marketing either. :p 22 Amps per rail on dual rails is a feature you can appreciate :)
Perkam
Same here:toast:Quote:
Originally Posted by uOpt
For anyone interested in quiet and performance you might want to wait on the new PCP&C Silencers coming in April.
10.225 x 3 = 30.675A ;)Quote:
30.675A x 4.82V = 147.8535w
Glad I'm not gonna be running SLi or Crossfire, I'd be a bit paranoid about the safety of my hardware, even with this OCZ 520.
Anyone tried the Silverstone ST56ZF yet ? It has that PCP&C something ... solid built, no bling-bling, all black, single 80mm fan. It also comes with one beefy 12V rail, pushing 38A sustained and 45A peak, dual PCI-e connectors, and a sexy chopper inside.
I'll throw FX-60 and Crossfired X1900XT's at it tonight, to see how it does ... the only think lacking is the adjustable rails.
http://img78.imageshack.us/img78/460...e0034rz.th.jpg http://img126.imageshack.us/img126/7...e0045xf.th.jpg http://img129.imageshack.us/img129/7...e0056sv.th.jpg http://img228.imageshack.us/img228/1...e0063nd.th.jpg http://img131.imageshack.us/img131/9...e0072mg.th.jpg
PS: it's also very decently priced around here too, about 2/3 of the price of a OCZ 520W.
How will they compare to Seasonic S12 600 in terms of "performance" (wattage, rail stability etc), and most importantly: inaudibility (silence)?Quote:
Originally Posted by chunkylover77
Linkys?
I would love a version of my 850 SSI as quiet as my S12 600... :slobber:
That PSU looks good. If you don't mind, you can maybe take the cover off and find some pots within the housing. Also, do any of these recent PSUs use sense wires? (like the older Antecs - the new antecs still have them i think)Quote:
Originally Posted by Micutzu
It's priced about $165AUD here compared to OCZ 520s at $230AUD.
Looking forward to your results.
be careful to make sure the right ends of the modular cables are plugged into the psu with Silverston ST56F, as folks have killed cpus and hdds with accidently plugging wrong end of modular cables into the psu and components!
This PSU is another version. It's not modular.:stick:Quote:
Originally Posted by eva2000
BTW, I have that PSU. It's a sexy beast, but I'm worried about whether, it can handle 7900GTX in SLI or not.
Unfortunately they don't use sense wires :(Quote:
Originally Posted by GMX
I'll get to it tomorrow when i'll get back to work ... anyway it seems like a great benching PSU, especially for that price. I'll even go that far that i will say it's better than the 520W Powerstream as far as benching requirements go, can't wait to see who's making it's electronics.
Krille all I got was an email from PCP&C saying that there new more powerful Silencer's were coming in April/May. I will be waiting till then.Quote:
Originally Posted by krille
Same here.. when they come out.. I know I'm getting atleast 3..:DQuote:
The Silverstones are supposed to be pretty loud.Quote:
Which was also the case for my PCP&C 1 KW, BTW. It's wasn't so much the volume of noise, but the fan had a very mechanical sound to it, as opposed to a wind sound which I find less annoying at same volume.
They have 120mm fan models too but generally yes, the Zeus series is pretty loud. From what i've seen so far, it's similar with the 510W and 1KW Turbocools as far as noise is concerned.
