Beat 20k on CF ffs...
Awesme job!
And yes we need to see what you can do with CrossFire!
16k... Very nice :toast:
Is that two raptors I see in the hdd cage? You mind throwing them in some RAID 0 and taking PCmark WRs? :D
OCZ 600W. But I would want my 520W back. It has proven to tackle more load with one grafic card.Quote:
Originally Posted by jpharg
Impressive! :toast:
16k with single card:slobber:
He will...soon ;)Quote:
Originally Posted by BlackX
Perkam
This is in normal ambient temp with stock coolers. Open window got me 740/880 on cards :) Memory only at 241MHz with T2 cmd rate (3.2V). Using a vcore modded ASUS A8R-MVP.
http://www.kinc.se/17243.jpg
http://www.kinc.se/crossfire.jpg
Kinc,that's insane.
17k all air cooled:D:D
Congratz.
Temps?
About 20C inside when I did this run. I remember when I did 17k all aircooled on GTX512 SLI, that took much more effeort compared to this.Quote:
Originally Posted by Godmaster
Amazing air result Kinc:)
Originally Posted by Kinc
I want more, damnit! :D
Kingpin has determination...but the cards have their limits. Also, he has hipro slashing up his 01 scores :p: so his WRs are being attacked on more than one front ;)
Perkam
http://www.nordichardware.com/skrive...8/ksystem7.jpg
Those boxes arent full are they? makes me :slobber:
LOOK at that Big typhoon, soooo badly mistreaded!
Send that bad boy my way, Kinc :)
Warming up with crossfire. Getting a new rd480 board tomorrow. This one is really limiting in terms of memory performence.
18 377 3DMark 05: http://service.futuremark.com/compare?3dm05=1808653
11 314 3DMark 06: http://service.futuremark.com/compare?3dm06=131731
http://www.kinc.se/cfln2.jpg
thats warming up:stick:Quote:
whats it like when its boiling then:slobber: :slobber: :D
Nice....almost 18.5k...is the fx not benching at 3.5ghz ?? Cos I believe that'll hold you back too.
Perkam
Yeah it is. Its just that the memory maxes out at ~245MHz on this board. This was the best ratio between mem and cpu clock I could have, memory performence is really important for the score in GT1. 234x15 resulted in a few points worse score then 245x14, new board will run this memorys at ~275MHz with tighter timings, should be a healthy boost in performence. The vcore was also droping alot wich gave me some problems above 3512MHz. A really nice board for the buck though :) New board here now (still rd480). New one should be here pretty soon ;)Quote:
Originally Posted by perkam
haha...Willis don't write checks that I can't cash lol ;).Quote:
My scores aren't going anywhere near 20k, with these cards without faster cpu clocks. Perk is right on about having limits...there is only so much possible.
Well done so far Kinc and awsome benching :toast:. I know you will show us what these cards in Xfire are capable of Marcus.
Its going up and up:toast: Nice work with CF there KINC:)
In truth I've just been amazed that you have been the sole force behind giving Nvidia the 3dmark lead for so long after the faster ATI cards came out...the fact that the GTXs have fended off the X19 cf, even after all single card gtx512 wr's have fallen, is remarkable :up:Quote:
Originally Posted by k|ngp|n
Perkam
good luck on your way to 20K on the CF, I wish you a better master card and board! :toast:
did you try adjusting LOD? event. how much does it boost the score?
of course, gratz on the 16K with the single card :slobber:
Just completed my first session with the DFI rd480 board. Thers is more left in the rigg :)
19 017 in 3DMark 05 with crossfire done :) http://service.futuremark.com/compare?3dm05=1810759
Nice work Kinc. :)
Wow:) Nice one Kinc:toast: ...Few more htt jump and you and ATI will take the top spot.
