Good luck m8 ;)Quote:
It wont do it :-( Maybe I have a sucky one.Quote:
Originally Posted by Twin
I even tried doing ldt/multi : x4 instead just so it wasn't above the normal limit of 2000mhz but it should be ok right up to 2200 right?
No idea what the :banana::banana::banana::banana:'s going on, but i started a new thread with pic and stuff here:
http://www.xtremesystems.org/forums/....php?p=1343565
Hm, my other memory is some 512Mb OCZ Gold 4000 VX. It runs wicked timings at 250Mhz (2-2-2-8) under 3.2v, and I was able to make my FX-60 run prime stable at 250x12 (4x HTT Multi) using a straight 1.55v. I bumped my LDT voltage by .1 as well, IIRC. My temps went a bit high (saw 61 at one point) but it ran stable and gave me some killer memory benches. I wish I had another 2 sticks of that stuff, but instead I run my Corsair so I can play BF2 with 2GB at 1T.Quote:
can i ask how old is your cpu-Z?
Those shots were with the 1.31 version. I just updated and revalidated: http://valid.x86-secret.com/show_oc?id=80833Quote:
Originally Posted by dontloveme
I presently own an X2 4400+ and I've only been able to reach 2.6GHz rock solid for 24/7 use on stock air cooling. I'm presently considering buying an FX-60 and try to reach 3.0GHz for 24/7 use, and put my 4400+ on a small basic system for my TVripping and encoding while I'm playing on my gaming machine.
@gloatlizard: What are your temps using the stock air cooling at burn speed running two instance of Prime95 ? Cuz I only see 37 celcius in idle on your screenies with 1.5 Vcore.
My 4400+ with stock cooling at 1.5 Vcore is around the same temps than your fx60, but in burn, it raise a lot, around 55 celcius with the fan being noisy at full speed.
what do you mean with burn speed? at stock mhz/vcore? or burn in setting, so default + high voltage? however i don't use this cpu from so much time, it's there on the desk, resting and waiting for ricky's cascade, i hope it will work...
gloatlizard;)
by burn I met 100% cpu used.
With my 4400+ I got 37 @ stock speed in idle... if you have 37 degrees at full load overclocked, I'm very impressed!!!
inside the case my best overclock for 1m super pi is 3085mhz (220.4x14) which gave me 27.141 but that wasnt optermised, ie themes and the rest running, so should be able to get it in the 26s. also my highest is
http://valid.x86-secret.com/show_oc?id=87871
with 1.55v
