update
[mbot] NISCO PT - 6747 - A64 x2 3800+ @ 2753 mhz | x1900 XTX @ 793/1629[/mbot]
http://img148.imageshack.us/img148/8...marks061ku.jpg
update
[hwbot] Sveinbra - 6632 - A64 3700+ @ 2960mhz 2*POV 7800gt @ 525/1190 [/hwbot]
http://service.futuremark.com/compare?3dm06=118717
Joining the XS Top10 :toast: :
[hwbot]Tyrou - 6871 - Pentium D 950ES @ 4523MHz & X1900XTX @ 711/846[/hwbot]
http://service.futuremark.com/compare?3dm06=119169
[hwbot]spajdr - 5714 - AMD Opteron 144 9x305 (2750Mhz] & Sapphire Radeon X1900XTX 750/874[/hwbot]
DFI LanParty UT NF4 Ultra-D+ / AMD Opteron 144 9x305 (2750Mhz ) 1.575V + AC Freezer 64, Tagan EasyCon 580W
1GB PC500 DDR RAM (2x512MB A-DATA VITESTA) / Sapphire Radeon X1900XTX 750/874
5714
http://service.futuremark.com/compare?3dm06=121191
Ithink good result with X1800XL and especialy D820@4Ghz
It is mine result socrat_bg -it is me
http://service.futuremark.com/compare?3dm06=121079
5062 p
[hwbot] chefnr1 - 6352 - FX57 @ 3755mhz - X1900XTX-DICE[/hwbot]
http://service.futuremark.com/compare?3dm06=120752
[hwbot]Tyrou - 7294 - Pentium D 950ES @ 5067MHz & X1900XTX @ 776/823[/hwbot]
http://service.futuremark.com/compare?3dm06=127009
:slobber:
[hwbot]Tyrou - 7476 - Pentium D 950ES @ 5200MHz & X1900XTX @ 800/837[/hwbot]
http://service.futuremark.com/compare?3dm06=128665
Hi,
Mi score in 3Dmark06:
http://img430.imageshack.us/img430/2...ossinoc7nv.jpg
believe that this enough good comparing with others 7800GTX
Goodbye
EDIT
Jackarturo -- 5085 -- AMD 3700+ @ 2800 Air & 7800GTX @ 490/1346
[hwbot]Deathman20 - 4727 - AMD Opteron 170 @ 2.68Ghz - X1800XL @ 625.5/729[/hwbot] http://service.futuremark.com/compare?3dm06=131222
[hwbot]malficar - 6498 - AMD X2 4400 @ 2.77 - X1900 XTX @ 702|850 - Stock air cooling[/hwbot]
http://service.futuremark.com/compare?3dm06=118362
http://img138.imageshack.us/img138/7421/62067pb.jpg
[hwbot]Tyrou - 7521 - Pentium D 950ES @ 5243MHz & X1900XTX @ 801/841[/hwbot]
http://img131.imageshack.us/img131/9729/75212yu.png
[hwbot] bogdannovaceanu - 4828 - BBA X1800XL@602/702 830@3000 [/hwbot]
http://www.crazypc.ro/forum/attachme...1&d=1140195362
Might I ask how you pulled that off?? The score is nearly 100points higher then mine and yet you have a significatly slower CPU, and yet a slower GPU then mine. What drivers you using?Quote:
Originally Posted by bogdannovaceanu
i use catalyst 6.2,and it give a little boost for intel dual-core cpu!since i use 6 series of catalyst i have much more points versus other cpu on slower frequencies of vga , look here,on my old card,that i've sold it on week ago :http://www.crazypc.ro/forum/showpost...t=347........., http://www.crazypc.ro/forum/showpost...2&postcount=10 ....on crazypc.ro/forum.......................:toast:Quote:
Originally Posted by deathman20
and you see,on the X1800XL,i don't made overclock on the system(cpu,ram,mobo)yet :D
next week i will go to 930-cpu and Asus P5WD2-E Premium-mobo,and i hope i can make over 9000 point's.
look on the 2001,2003 and 2005 3dmark,on this forum!
and deathman20,what voltage yo use on 625,5/729? on my vga,on 602,1/702 i use 1,225@vgpu-2,102@mvddc-2,004@mvddq
[hwbot]Tyrou - 7541 - Pentium D 950ES @ 5259MHz & X1900XTX @ 801/846[/hwbot]
http://service.futuremark.com/compare?3dm06=136779
[hwbot]TinTin - 7010 - Sapphire X1900XTX 769MHz/837MHz A64 4400+@2808MHz WATER COOLING[/hwbot]
http://service.futuremark.com/compare?3dm06=137033
http://img487.imageshack.us/img487/3553/3d0670102yr.jpg
[hwbot] LyP0 - 4223 - sempron s754 2800+ @ 2727Mhz - asus 7800gtx256 @ 505/1435 [/hwbot]
http://service.futuremark.com/compare?3dm06=137544
1. register at hwbot.org with same nickname as here and team XSQuote:
Originally Posted by palehorse
2. click 'results' under profile
3. claim the wrongly submitted score
4. click 'delete'
5. edit post here
6.2s are nice. I went from 6141 to 6498 in '06 and from 12185 to 12692 in '05.
Old driver was the one from the CD that was included with the 1900. I believe it was a modified 5.13.
You can add me...
X1900 Crossfire on stock air with Intel 920 @ 4.06 Ghz on air.....
[hwbot] M Diddy - 8579 - 920 @ 4.06 Ghz ATI X1900 Crossfire[/hwbot]
http://moderators.20vturbo.com/mdiddy/Nero/06.JPG
[hwbot] I_G - 6007 - 955D@5Ghz - 7800GTX 639/1566 *aircooled*[/hwbot]
http://service.futuremark.com/compare?3dm06=141253
[hwbot]Tyrou - 9365 - Pentium D 950ES @ 5100MHz & X1900 Crossfire *stock cooling*[/hwbot]
http://service.futuremark.com/compare?3dm06=142170
EDIT : brought back the #1 spot for team XS ! :woot:
[hwbot] Zeimbo - 4715 - Opteron 170 @ 2700mhz , Aircooled - EVGA 7800GT @ 514/1200 , Aircooled [/hwbot]
http://i16.photobucket.com/albums/b24/zeimbo/4715.jpg
Opty 170 @ 270x10 1:1 (air cooled) + EVGA 7800GT @ 514/1200 (stock voltages/cooling)
3dmark06
SM2.0 score = 1871
HDR/SM3.0 score = 1839
CPU score = 2083
Score removed - posted an updated one.
