What are you using it for, besides having fun? :DQuote:
Originally Posted by bachus_anonym
Is it an indicator of anything pi- or prime-related?
:p: Too late :lol:Quote:
Originally Posted by njkid32
That's my thought, exactly... No other explanation comes in mind as it looks like it's not "latencies-related" but pure HTT/DDR speed. This is just another reason why FX users have it all brought on the plate, with unlocked multis :D It's probably better chance to do 298x12 than 358x10 div166... Damn rich people :lol:Quote:
Originally Posted by afireinside
It's on the par with 1M... I can do AiBench and 1M at same clocks. Not much else passes at 3.62GHz so far.Quote:
Originally Posted by stryg
32mQuote:
@ Bachus.....you don't necessarily have to be rich to have nice HW. Just takes a little bit of planning, some patience, and ALOT of luck :p:
Also, even with a FX57, I've noticed there are times where I have to "slack" my memory timings in order to complete a bench where it was stable @ a lower multi....
Yesterday I have finally finished vmodding that 7800GTX 512MB I used above, so I figured I might as well update with new 3D results. Stock cooling, 1.60vgpu / 2.45vdd. Those are my new personal records :p: :toast:
3DMark2001 @ 3534Mhz, 7800GTX 512MB @ 673/2080. Compare URL
http://www.clockmehigh.com/cooler/sc..._3DM01_8x6.png
3DMark03 @ 3440Mhz, 7800GTX 512MB @ 660/2040. I'm very dissapointed with this result and I seriously think I need a better PSU. I'm 100% sure my trusty Fortron 530W is not up for the task anymore (above 3.5Ghz & volt-modded card). Compare URL
http://www.clockmehigh.com/cooler/sc..._3DM03_8x6.png
3DMark05 @ 3520Mhz, 7800GTX 512MB @ 670/2030. Compare URL
http://www.clockmehigh.com/cooler/sc..._3DM05_8x6.png
OK... Uffff :)
Nice score in 05 & 01
did U try to pass 03 with less graph OC but higher CPU ??
I think that without Vmods score would be better with CPU @ 3530 at least ...
Nice new PR's !! I want 12k as wel :D
03 is a little harder on cpu compared to 01 and 05, at least in me case. I can run both 01 and 05 with almost 100mhz more on cpu then 03, first test wil crash always when on same clocks as in 01/05Quote:
Originally Posted by yotomeczek
Another terrific thread by bachus_anonym! Wish I could auto-subscribe to threads started by some of the elite members around here. As it is, looks like I'm late to the party because I've gone into full time game mode. I just thought I would be testing my Infineons. Lol.
This CPU may have been passed around like a biker chick but is no worse for the wear. Looks like its seeing its best days under bachus_anonym hands sans IHS. 110mhz gain on 32M just from popping the top! Sweet.
Bachus, thanks for taking the time to put the results together and sharing them. Congratulations on your new personal bests. Inspiring stuff!
bachus if you´re not satisfied with your Fortron PSU.
You can get an Seasonic S12 600W or Enermax Liberty 600W.
Best PSUs for Money you can get.
Congrats to your APMW.
@gundamit,
Thanks a lot, man :toast: Trying my best... :)
@loc.o,
Same here... I always need to drop MHz for 3DMark03, even at stock vc volts.
@Rufus7,
I have PC Power & Cooling 510W Deluxe, but it's hooked up to my other PC and I was just too lazy to swap it... :) Maybe it would have helped, who knows...
OK... I'm officially done :lol: I'm just gonna add two more 3D benches - fresh 3DMark06 and Aquamark3.
Aquamark3 @ 3530Mhz, 7800GTX 512MB @ 673/2080.
http://www.clockmehigh.com/cooler/sc...88_AM3_8x6.jpg
Fresh baked 3DMark06 @ 3500Mhz, 7800GTX 512MB @ 660/2040. Compare URL
http://www.clockmehigh.com/cooler/sc..._3DM06_8x6.png
Now, thread is complete :D
Nice Opty, now if we only had a 170 that could do that :)
...climbing up to the 2nd fastest AMD non-FX 32M result: SuperPi 32M @ 3594MHz!!!
Still on 2x1GB Infineon CE-5 sticks @ DDR512 5-2-3-2.5-1T and only 3s shy of coop's time :)
http://www.clockmehigh.com/cooler/sc...12_32M_8x6.png
This chip is just amazing :cool:
Very nice man! Jeez everytime I look at this thread it just gets better:) I know you have at least 4s more in ya.
359 HTT 150 divider 3594 :eek: That's fantastic. :clap:
I've not seen your true oc'ing ability since I've been active on this forum. I do know that your testing of memory is bar none the best.Using your skills to take this opty to the level you have has shown me that you are a true XS legend. There is nothing like watching a master work, Thank you for sharing it with us.
Originally Posted by coop
Thanks a ton guys! I'm not finished yet, though...Quote:
Originally Posted by dogsx2
I'm still hoping that with some UTT I will improve SPi results a little ;)
Originally Posted by Patrickclouds
...swapped to TCCD again and here we go: SuperPi 1M @ 3595MHz!!! ---> 22.xxx here I come :woot:Quote:
Originally Posted by 5days
http://www.clockmehigh.com/cooler/sc...598_1M_8x6.png
One more shot: Pifast @ 3550MHz!!! I'm really having hard time keeping that TCCD stable above 295MHz 5-3-3-2.5-1T at this combination of high HTT and a div166. Normally, this RAM flies up to 304Mhz at div200... I can't wait for that UTT that may be coming very soon :)
http://www.clockmehigh.com/cooler/sc...Pifast_8x6.png
jeeze bachus, your relentless. Good stuff. I could not get to 22s.
as always whenever i troll through looking at the threads you start Bachus you never fail to impress. can you try the new 3DMark 06' to see what you get with those crazy clocks?
Me either. Hopefully you get a hold of some high flying tight timing UTT this weekend. Amazing results thus far but with the tight BH/CH/UTT you'll send this thread right over the top. :slobber:Quote:
i'm envious now :slobber:
very good chip and and a great work on it :)
UTT arrived this afternoon so thread needs an update :D I came back from work two hours ago and...
...the new SPi32M record for "AMD non-FX" has just been born...
http://www.clockmehigh.com/cooler/sc...10_32M_8x6.png
I also have another result @ 3590MHz but the "problem" is, that I thought I grabbed a screenshot of it but apparently I did not :brick: So, what below is all I have as a proof :( I have not succeded to repeat this time but I will try again tommorow...
http://www.clockmehigh.com/cooler/sc..._record_dc.jpg
Thanks for attention :D
OK I am at a loss for words! Thats it I want it back! Great job Michal jeez your like the energizer bunny.. you just keep going and going.....
Also, just curious what is the highest ss you have gotten?
:D :slap:Quote:
...it's mine, my precious... :devil:Quote:
I have not tried any "suicide shots" and I don't think I will :p: :cool: I strive for benchable clocks only :D
EDIT: From what I have seen though, I'm not absolutely convinced If I could ss @ above 3.7GHz...
I know you only bench I was just curious what it would top out at. I see the new ss WR is 3.75ghz but cant bench as high as yours so I would say yours is the record holder:) Good job!
Hey BA, hopefully you will have some competition in the next week or so. The younger brother of your chip has been bought by a forum member here at XS (batch#036, currently in my sig), the person will try it on DICE, and maybe a LS. Hopefully the results will be good. I know a friend of this person has some very fast BH-5 ram also
I wont reveal any names, i will let them do it, heheee
