Opteron 146 0540 FPBW
Vapochill XE
http://slike.slo-tech.com/16763.jpg
Vapochill XE
CABYE 0540 FPBW - 2800 MHz - 1.452v Stock-AIR - GoThr3k
well i cant post a screen, because my parents are devorced, and my main rig is at my moms place, i will post a screen asap
Opteron 146 CAB2E 0540 FPMW @ 2.9G stock volts w/ superPI 32mb on stock shuttle sn25p cooling : http://www.xtremesystems.org/forums/...ht=shuttle+air
good work is this CABYE?Quote:
Originally Posted by GUFY
all FPBW 0540 are CABYE's i thinkg
CABYE 0540 FPBW and betch 156.:D
Tuned...hope to have a opty soon under my hands...
Opty 148
CABYE 0536 GPMW
2900 mhz @ 1.41 volts
Air cooled with TT Big Typhoon(27 idle, 43ish load)
prime stable 24hrs and stable with occt, S-n-m, pi and all 3dmarks.
Will probably do more, but I am extremely happy with 2900 atm.
-Elo
osa148daa5bn
cacje 0546bpmw
Max stable o/c is 295x10 @ 1.63vcore, my corsair tccd runs @ 1:1 nicely with this processor also.
The following tests were done at 294, but since I have redone at 295 and it remains stable.
Heres a days worth of memtest
http://img74.imageshack.us/img74/173...test6kd.th.jpg
Heres my config
http://img74.imageshack.us/img74/540...ings9mx.th.jpg
Heres 10hours of Large FFT's before I got an error. I think its heat related, tracking it down still
http://img498.imageshack.us/img498/5...29408cx.th.jpg
superpi 32m stable as well if you need a screenie, i'll have to re run it. I game with this setup and it hasnt crashed once.
Sounds good. The reason I suggested that is because max clocks will be alot different between various stability tests. For example, since optis run so hot, you can usually run a 32M at close to 100Mhz higher speed than you can run prime over a longer period. Standardization of stab tests will give more of a apples to apples comparison so people will know what to expect. :)Quote:
Originally Posted by Daveb2012
Ill add results from a 148 and 150 later tonight.
Elo I beleive you but please post some pictures of stability such as a prime test when you get a chance.Quote:
Originally Posted by Eloman23
Here's mine @ 3104mhz and 1.6v on H20
this was on the abit av8 that reported temps rediculously high. Now I'm at load of 38 to 40C on nf4 ultra-d
http://img439.imageshack.us/img439/6...51044298bk.png
Dave -- updated results. I did a little extra pushing with some cooler room temps, but still nothing outdoors. on TT Big Typhoon, IHS removed, AS5 applied.
:toast:
Forgive the GIF compression - just used a quick paint grabbie. But the new speed is 3133 1.600v air. Please update the results. Also take note -- this is on a pretty messed up windows install that is not fresh and I wasn't going for low pi results or anything. Just solid benching. I may post some updated pi results with tighter timings if I can.
Thank you
P.S Absolute's results need to be changed. His cpu-z screenie says 1.6v at 3196, not 1.504.
CABYE 0528 GPMW 2863 Mhz 1.45v Air - 4X4N
24/7 settings. 32m stable at 3.0ghz, but can't find screenie. I'll run it again. Looks like I need to update my mbm dashboard.
Edit: Just ran 3.0ghz 32m. Here is screenie.
http://img5.imageshack.us/img5/1821/...25hr5qz.th.jpg
http://img42.imageshack.us/img42/1266/3032m7mz.th.jpg
CABYE 0540 FPBW, stock 4800+ cooler, 1.55v bios
http://img6.imageshack.us/img6/5095/3000prime4cj.th.jpg
Good stuff. :toast:
CABYE 0540 APMW - 3100 MHz - 1.568V H2O - starostise
http://membres.lycos.fr/starostise/O...00MHz_1.56.JPG
CPU Type: Opti 148
Stepping: CAB2E 0546 PPMW
Best Stable OC: 2990Mhz
VCore: 1.56v
Temps: Idle 29C/Load 44C
Cooling: H20
http://members.shaw.ca/zryan/148-7.JPG
CPU Type: Opti 150
Stepping: CABGE 0534 SPMW
Best Stable OC: 2950Mhz
VCore: 1.63v
Temps: Idle 23C/Load 38C
Cooling: H20
http://members.shaw.ca/zryan/150-7.JPG
thanks your the first to to post the format like I asked. good results.Quote:
Originally Posted by starostise
CABYE 0542 FPMW - 3180 MHz - 1.65v- Water - Malph
http://img12.imageshack.us/img12/764...8spi32m6gc.jpg
CABYE 0540 FPAW - 3443 Mhz - 1.778v Phase Change - ncsa
http://img224.imageshack.us/img224/4...3ocn5mc.th.jpg
Opty 148 CACJE 0546 APAW on air HSF Gigabyte G-Power Pro
Suicide screenshot close to 1.7v vcore
http://img.photobucket.com/albums/v6...e/14832cpu.jpg
http://valid.x86-secret.com/show_oc?id=65403
Max. stable on air : vcore 1.58v
http://img.photobucket.com/albums/v6...14830pi32g.jpg
do opteron 148s have cold bugs?
most CAB2E steppings coldbug badly
What is the RIP for did this already die on you?:slapass:Quote:
Originally Posted by ncsa
