Originally Posted by Tony
Tony,
have you tried the VTT mod on the Expert too?
KK
Tony,
KK
any updates?Quote:
Originally Posted by MaxxxRacer
Opty 146 CACJE 0546. Did not boot at -10C, that's how severe it gets. Now how to work round that? The last one I had, I tried staging the boot and phase power up.... resulting in one dead CPU. Now I have another 146 from the same batch, same performance on air as the last and, I'm betting, same degree of cold bug. So I'm interested in finding a way of making it boot safely and not trashing it. Perhaps the Vapo LS controller will let me try booting at +5C or more; it means that any reboots will take a 30 minute break to warm up.Quote:
Originally Posted by bachus_anonym
Any ideas?
Even if you can tweek the system to boot early you will still have problems when the vapo gets to operating temps.
multi-tweak? :confused:Quote:
multiprocessor tweakQuote:
Originally Posted by deff_ins
So if I am running 2 x 1GB I should be running 9-15 on the expert under phase?
sorry, can anyone give me some hints on the multprocessor tweak and how to enable it, and any advice on drive strength levels for the Ultra-D
Thanks a million :)
Kenny
RMB on My Computer > Manage > Device Manager > Computer, I believe.Quote:
Originally Posted by K404
Yup, sorry I got it just after I posted. God bless google :)
Cheers!
Kenny
Good info. :toast:
just wanna let everyone knows
9-15 for 4 dimm
1-8 for 2dimm
according to Oskar Wu in Nov. 12, 2005
here in Latvia was very cold some last days. about -25C. so we used cold air to chill down vapochill ls to emulate DI :D lovest temp on vapo lcd was -69, in bios @3.2ghz -35, in windows -33.
so - this time we tested on expert board. most intresting thing is that @-33C - and no coldbug. on sli-d with same conditions coldbug was at -27C :confused:
full test setup:
dfi expert (no coldbug @-33C windows working fine - no OS freezeng)
dfi sli-d (coldbug @-27 windows freezing, windows bootup imposible)
opteron 170 @3.2Ghz 1.62v 3d benchable
mushkin redline hp3200 (drive strenghts: 8/3 on sli-d | 7/4 on expert)
antec tp2 550w
vapochill ls
i have tested diffrenet drive strenghts combinations on sli-d - no change...
so - tell me why on expert cpu has no coldbug @-33 but on sli-d it has?
P.S. sh** my english is lame :(
i read all that thread, im using sli -dr , 2x256mb bh5 what drive strengt then i need to use... ? i hate that damn coldbug :|
hmm... i tried this settings - drive & data strength - but with my FX they wont work. My prob is that i cant get a high HTT, but if i´am using a higher multi i can run spi about 3,55Ghz. So what is limiting my HTT ? :confused:Quote:
Originally Posted by s7e9h3n
thanks for some hints ;)
cu
Sounds like a cold-bug to me....what stepping 57? And @ what temps?Quote:
Originally Posted by Sauron_Vie
it´s a 0531RPMW and i have @idle about -25° and @load about -7° if i use Vcore about 1,65 to 1,67V.
i reached 3,55ghz with multi 15, but i cant go up with the HTT and lower the multi. if i do that, i get a freeze evertime. :mad:
Attachment 42696
cu
Yup...cold-bug it is....CAB2E correct?Quote:
yep stephen, u r right. damn and ok, this baby will find the way to the marketplace and i have to take a look for a new one... lool :D
many thanks for the quick reply buddy ;)
cu
wow Tony! You amaze me :)
I love this forum :)
ya.... its all about drive strength .. nice find :toast:
I've been playing around with settings on my bugged 170 and expert now. Want to know what they do? N-O-T-H-I-N-G. This is the biggest load of crap I've seen in a while. You name a combo I've tried it. This will not work.
who said that this is the answer to all problems .....you should know betterQuote:
Originally Posted by afireinside
Well I never said it was a cure, some CPU's will see a gain some will not. fact is we are running CPU's at temperatures that they were not designed to run at and motherboards too for that fact,just because it does not work for you does not mean others will not see a gain.Quote:
All I can say is design of motherboards continues, companies are now factoring in that more are using subzero temps so will will see small gains with each design.
So these companies care about overclockers? seriously? I know that sounds sarcastic, but do we make enough of a difference to their sales?
Does AMD care about cold-bug, do you think?
K
