update every 6 hours.
Thats probably why, thanks for the help.
Yeah, you're showing up just fine here :toast:
http://boinc.bakerlab.org/rosetta/te...redit&offset=0
I'm in :) Installed on a p3 for now but when I get home after the hols it's going on my X2.
Oh ya... Happy New Year all :toast:
Someone needs to do correct some spelling at XS's Rosetta page.
http://www.xtremesystems.org/forums/...1&d=1136088337
Someone needs to change this to renowned.
Anal little fecker, ain't I? :D
Doesn't this mean we should sticky this IN A NEW ROSETTA FORUM :D
Another Year, Another Project - OH FUGGER PLEASE :D (And thank you)
I've decided to come join the push on this project. Its looking like it could be a good one like d2ol but hopefully without the other stuff involved this time. Oh and i tryed the new client that shmaa gave a link for and it doubled my bench! (also tried the one moddolicous gave and it slowed it back down again) so Ive gone with the first one.
I've got a question: my rig downloads work and is doing fine except for one thing: it does about 3/4 workunits and idles a lot in between. Now I tried to find out what was wrong here, but I didn't find anything at all.
Any help is welcome, I want my rig to run full throttle all the time :)
Ok... who just edited the team info? I'm the only one who can do it and I was going to, and it was edited.... time to change the password methinks
Originally Posted by Entity_Razer
It was me remember Im XS_VIP so I have username and password in order to add clients to the account. Thought that I would just do the job while I was online.
In general preferences, is the option "Do work while computer is in use" on "no"?Quote:
Originally Posted by Martijn
If it is, set it to yes and see if that fixes our problem. :toast:
It was, thanks :D
count me in guys =)
You'll have to manually update your client for new preferences to take affect. Forgot to mention that. Then you should be full throttle 24/7.Quote:
I know, it said so when I pressed the 'save stats' button. It has now 4 wu's downloaded and is running 100% for the first time whilest gaming :)Quote:
Originally Posted by shmaa
alright I'm a tad confused. I installed everything like it said on the first page, now what do I do? I'm at a "Project URL" thing in the BOINC manager.
edit : OK here's where I'm at. Is this right?
Copy the link below into the project url place.
Originally Posted by DamienKC
Enter: http://boinc.bakerlab.org/rosetta
Then it will have you create your account.
Once you have your account created, close the BOINC manager and install the SSE2 optomized files found here: http://www.bm-makler.de/setiathome/b...lon64_SSE2.zip
Just unzip them right into the BOINC folder.
All the options for how the client runs are changed from the website found here: http://boinc.bakerlab.org/rosetta/home.php
Don't forget to join XS before you submit any finished work.
Hope that helps :toast:
Like I said, I created everything, the optimizations are in, I just don't know how to make it start.Quote:
There's nothing under the "work" tab or anything. Pretty sure nothing is happening =P
I have a Q.
How many clients can you run with a DX rig or a64 rig,is it the same as D2OL,DX rig 4 clients,ore just 1 client for 1 rig.
Can somebody inlight me:).
1 client for 1 rig.
you might need to go to your preferences on the website and set it so rosetta can use up to 4 cpu's (not sure if it will use HT though).
So what does rosetta prefer?
High clocked A64?
P4 with HT?
is the output of dualcore/dual processor 2x a single core in rosetta/?
Yay finally got some work. Only does 1 at a time though =\
my dual core is chugging through 2 threads at a time... thats all i know.
