here are some pictures of my card :)
www.kirkkirk.dk/Vmod.doc
Mine was not an XT thoug :)
Nice pictures. :) PCB of your card precisely same as mine. The real 5900 had identical PCB with 5900 Ultra. Were usual 5900 which used PCB from 5900XT, and I used BIOS from such card for my 5900XT. :)
tehres a big performance increase from sli on 955 to sli on 975?y? isnt 16x and 4x about the same as 8x and 8x?
975 is faster than 955 about 10 - 20 % depending on a situation.Quote:
Originally Posted by grimREEFER
http://www.hkepc.com/hwdb/65nm975x-10.htm
3dmark 03: 11975
3dmark 05: 5167
opteron 144 0536 cabye 1,66v 3106 mhz
2x256 mb corsair BH5 @258 mhz 3,3v
DFI nf4 SLI-dr
160gb Hitatchi sata
All watercooled (by asetek) + alcohol ~ -0*
6600GT by leadtek @680/1386
my single 6600GT result :slapass: :stick:
Lol hehehe!!Quote:
Originally Posted by xooler
Good job dude!! :cool: :cool: :cool:
Well done man.
Finally our record has been broken and congrats on the 20K I knew it was possible with a 6600GT.
sponge bob
I also tried a single card
03Mark - 12276 http://service.futuremark.com/compare?2k3=4501099
In 05 result enough bad, I have bad GPU and on 650 I have not held on up to 5000 a little. I think that on 680 it would be not bad.
yes i saw that... how btw can u get ur memory so high ? cap modd? my memory @2,3v is optimal... over this just heats it up and no go , powercircuit sucks...Quote:
Originally Posted by Big_Sam
ill go for new round... i just saw that my hdd was ~ 1*c :slobber:
and LOL i forget to clock my cpu higher :p: and anyways ur 5,3 ghz p4 is awsome in 03e ... what is ur max spii 1m time ? i can get 26,5 only
I did nothing with memory. Cards so worked at once. To me advise to make Vmem mod and speak that there is a chance to receive 1500.Quote:
Originally Posted by sponge bob
So... :) now my first run 2 x 6600GT on P5WD2-E (i975)
http://img219.imageshack.us/img219/951/97505m9vt.gif
http://service.futuremark.com/compare?3dm05=1783963
I think - not bad for the first run :)
Nice Intel power over there, Big_Sam ... how's 3DM03 on i975 ?
wow really nice...
and what about NF4 with Asus P5ND2?
Thanks for sharing your latest project! I really enjoy watching your work.
And very nice scores, too! :clap:
very nice! bring some more home for intel!
stick thoes cards on a 975X chipset with 8x/8x slots instead of 16x/4x and you should scale even higher :)
Thanks for congratulations. :)
Has made some attempts in 03 and 05, on 77.72 and 81.85. My system obviously works better on 81.85 in 03Mark, and in 05... for the present has not understood. It seems to me that any small problems with mine CPU phase-change and consequently I could not pass tests on FSB=377Mhz yet. I think that I shall repeat attempts. :)
http://murenacat.com/sam/files/05_8907.gif
http://service.futuremark.com/compare?3dm05=1795281
http://murenacat.com/sam/files/03_20627.gif
http://service.futuremark.com/compare?2k3=4614587
I think that in 05 I can reach up to 9000, and in 03 up to 21000 :)
Still wished to tell, that P5WD2-E very good device, with one enough greater bug. Distance between PCI-E too small for installation of qualitative cooling system. Between my Zalman-700 and a plate from another Zalman on a underside of the next card there is a distance of less millimeter.
http://img206.imageshack.us/img206/2497/p5wd2e1ti.jpg
very nice stuff inside, nice mem speed :O i maxed out 1406
go for 21k @03 ;)
nice stuff i may need to run some more 66gt's runs been a wile but nice 03there:)
