lol, no, vapochill units are single stage compressor cooling units :)Quote:
I like mips shots, don't bug me about what uses them please...
I don't ask you how come you like seeing how many seconds something takes do I ? haha...
yes, a vapochill is for 24/7 use.Quote:
Philosophy- Is vapochill not like a small time usage thing? you can have this set to run a long period of time?
it's not like LN2 or dry ice, cause it's not just a chemical in a tube, evaporating away real fast.
it's controlled cooling.
the highest 2k1 run is at 5.5ghz?Quote:
Originally Posted by harleybro
i dont think 8ghz is possible even with ln2 if the max bench speed is 5.5ghz with a vapo.
but why do youlike mips? because it shows high numbers? colorfull bars? ^^ seriously, it has no real world relevance afaik.Quote:
Originally Posted by Kunaak
and if you mean superpi with the second remark, superpi shows the cpus fpu performence and cache and memory performence wich indiacte how the cpu will perform in games and benchmarks.
doesnt someone here make vapo chills modded?
I really need awesome cooling for my next build..
Chilly1 correct?
I can do 3D at 5.8Ghz
At 5.6hz I can run stuff straight through without worrying about vapo dropping temp.
This chip will not make it to 8Ghz but I do have a good shot at breaking 7Ghz
Yes Phil, Chilly1 does the vapo mods and custom builds.
New Intel cpu = nice scores ;)
X1800XL speed :clap:
We want more.
Very nice Fugger amazing on a DC cant wait to see the cascade on this.
This new P4s looks really good! :toast:
Not P4, Core :DQuote:
Originally Posted by funkflix
Ok, no P4 then. :D
can't wait to see the colder results ^^
Looks like intel really have made the "more megahertz the better" motto work for once...which is weird...
someone already asked, but this thing gets hyperthreading right, since its an EE chip? so sorta 4 cores? Amazing clocks, and i'm looking forward to what it will do on the cascade.
These appear to be very good chips so far.....But how do you guys think the retail versions of these newer cpus will work? none the less looking good there Fugger.
Tim
I have had several Retail and ES chips - with great and mediocre results on either side - don't think it'll make any difference
Sorry not familiar with the vapo is the display evap temps also is it loaded at those temps.?? If not what are the evao temos. while loaded? Any PI runs coming? Ok no more questions for now. Get that sucker on the cascade and the vr out where you can access it. :) This 955 is realy impressive so far and to think it's being run on a chipset that it wasn't supposed to. Nice work. :toast:Quote:
-43c on display and core is at -21c bios @ 5.8ghz
Harleybro, loaded temp drops about 2c, I am set for maximum capcity as I was using 840EE. unloaded at stock speed it will drop back as far at -47c on the display.
Pi runs so far
http://www.xtremesystems.org/forums/...1&d=1135317252
the 32m was from the 3.73EE
I assume a pifast ( Hexus flavour) is below 40 seconds by a comfortable margin ?
I agree with Kunaak, if 975 chipset did Sli then this would make a very good 24 hour general use / multimedia / gaming rig for us folks with nvidia video cards. Being cheap I'd probably end up buying Cedar Mill though :D
I think this could be a nice last hurragh for Netburst.
Regards
Andy
kyosen ran some 01 at 7.2 on a 670 ;)Quote:
Originally Posted by saaya
Hurry up with the 3 stage!
This rig is set to be a killer 24/7 HTPC gamer with ATI cards.
These cpu's look killer :toast:
I see that already.Quote:
Originally Posted by FUGGER
Will be interesting to see how AMD compares to Intels newest offering, looks like Intel may have finally gotten its act together ;)
is that 3.46ghz, 2x2mb cache (4mb), dual core + HT ?
CorrectQuote:
Originally Posted by Supertim0r
