Originally posted by veeman
I could not get a 1mohm potentiometer so i got two that are 500k each. The potentiometer has three prongs coming out of it. i soldered a 1mohm resistor to the little pin and it goes to the first prong,i then soldered a wire coming from the second prong going to the first first prong of the second potentiometer then i soldered a wire coming from the second prong of the second potentiometer going to a ground (one of the screws that hold the mobo) .When i check the voltage all i get is 1.53 all the way up ,and all the way down. did i not link the two potentiometers together correctly? please help i want this mod to work.
ok, that sounds like is not making contac on the board, and to know if you link them correctly measure them before putting them on, also make sure put connect to the lower tip not the higher as illustrated on post 13 and try again and never lower all resistance;)
