of course he uses a pentium M. its the fastest cpu you can get right now. nice work man!
I'm getting there slowly with a bit of OS optimization :)
http://service.futuremark.com/compare?3dm05=1654827
Originally Posted by ingentingmendeg
:D :D :D You are right, my first tweak is to use a pentium M on air, which needs a 3,1 a64 to be beaten on air or a good X2 cpu like 2,8 or a bit more.
Second, which I have not yet applied is "want extreme points, go extreme cooling", on air that means putting a thermalright sp97 on a 6600gt.
I'll update soon with pics of the vmods and the cooling.
That's a pretty expensive "tweak" ;). I can't afford to replace either my processor or my motherboard unfortunately :(.Quote:
I just broke 5K with my entire system stock. Only the card overclocked, to 688/1323.
http://service.futuremark.com/compare?3dm05=1659313
That's 2.2 GHz of Athlon64 POWAH for you ;).
Here you can see a compare between my 5k+ run and yours. I was at 650/1272 clocks.
Compare
but with a CPU that is like 2x faster in 3D lol...all of u guys are doing a GREAT job with those cards keep up the work and throw some dice at ur cpualways and ur card and let her FLY to the moon!!!
Dragon
im waitinf for my dryice ;) my last watercooled results were 11.8k 5,1k
Niiiice spongebob, let's step this up a notch! :)
I'm looking forward to seeing what this core is capable of under really good cooling!
I have a DI tube here waiting. SP97 ready to be sent to the cnc mill to be adapted to my 66gt, backplate is also going the same way. First I will max out on air, then will be CPU on DI and after that everything under DI. Will be some real fun.Quote:
Originally Posted by FireDragon
You guys are crazy :)
I'm looking forward to breaking 5.3K with you guys :D
I've got my Prommie hooked up, going to get to work on my memory and processor soon, see how they fit into the score.
Xtreme cooling for Xtreme systems:
http://img266.imageshack.us/img266/9494/xtreme4ky.jpg
SP97 on my 66gt, still have to tweak the mounting to get best contact. Looking awesome so far.
Uh, I have to find something huge to keep up :)
very nice work Always!
UPDATE: With ambient temp beeing 22ºC I'm having 37ºC idle temps and 43ºC load temps at 610/1250 core/mem respectively. Have to tune the mounting yet because I'm currently on zip ties+Zalman bracket:
http://img73.imageshack.us/img73/1079/xtremeee4zt.png
