Well get back to the bench GS. :)Quote:
anymore news on this ram?:confused:
Well, I picked mine up on friday, but have been pretty busy, so didn't have much time with them to play and test them.
Plugged them in my DFI SLI-D (tony's 704 bios) and started some initial testing.
It looks like they max out at 240Mhz, with 2.5-3-3-7, 1T timings and 2.7V.
241Mhz with 2.5-4-3-7 looked ok too but that's it.
I couldn't get them higher, no matter the timings or volts.
245Mhz with 3-4-4-8 timings gave me lots of errors in Memtest, so I didn't bother trying to boot into windows and try superpi.
240Mhz with 2.5-3-3-7 timings isn't that bad at all for this value ram.
To bad I couldn't get them much higher though.
I might try some other timings within the next days, but I don't know if it will change a lot.
http://www.xtremesystems.org/forums/...1&d=1134420014
http://www.xtremesystems.org/forums/...1&d=1134420200
awesome. do you know what it says on the chips?
edit. is this the 2gb kit insteada the separate 1gb sticks?
Nope, that's the seperate 1Gb sticks.
I'll take a pic from them later.
those are pics of the 512x2 kit!Quote:
Originally Posted by Jupiler
Oh crap. You're right, sorry about that.
I bought the 2*512GB kit for a friend. He needed some cheap ram so I got those while I bought the 1Gb sticks.
Pics of the chips :
http://www.xtremesystems.org/forums/...1&d=1134493893
god damn im crapping out at 220mhz 3-3-3 on my dual sata2.
heres what it says on my ic
C64M8G7249E-5
you must have a newer batch since you are 266E-5
so why do i suck?? aaaah
also. what is your serial number, i see another sticker on it.
you might want to try CL2.5, they don't like CL3 setting in my caseQuote:
Originally Posted by galadar
ok here goes! stay online gskill technician!!!Quote:
hey does gskill have any more old batches left, how bout i rma these bad boys?
or trade with you? i wanna trade with you1!!!!! you have holy chips.
ok im testing one stick at a time.
so far!
dual channel and individually tested.
SuperPi Stable
230 2.75v 2.5-3-3-11 (11 for uli chipset)
235 2.75 2.3-3-3-11 /2.5-4-4-11Crashing.
more tests to come.:toast:
if you have a bad ram need to ram, we have old ones in stock.Quote:
OMFG are you kidding me?Quote:
are you the one in charge of rma and etc? are you sure of this?:woot: :woot: :woot:
i am the one control all USA shipmentQuote:
what kinds old memory u need to RMA? or you mean you want some "old week" memory then that is harder to find
i was thinking of the serial numbers close to yours.Quote:
Andre Yang and you both have 051105101xxxxx and they overclock great.
i have from newegg(which is probably quicker on batches)
the s/n is 05110510223869
so maybe thats why. and teh guy above me got his locally which stock earlier sticks due to less demand.
galadar :
235 with 2.5-3-3-7 is pretty good for this cheap ram.
Remember that they're value ram, way cheaper than the HS, HX, HZ and ZX series.
They're rated to run at 200Mhz with moderate 3-4-4-8 timings.
So we might consider ourselfs lucky for having them running at 230+ speeds with 2.5-3-3-7. I think that most of them might do around these speeds, with some occasional exceptions like andreyang's chips.
So an RMA for good working sticks is out of the question, IMO. They work as rated, you got even more than expected. So there's nothing to complain about. :)
well mine only go 230! maybe its people like andre who make us expect too much.
Well,
it's a crapshoot, as usual. Some will clock higher than others, just like cpu's.
Matter of luck, that's it.
But yeah, guess we get spoiled to much and sometimes expect to much from our hardware. :)
hey jupiler, nice to see a fellow belgian here :D
where did you get this ram in belgium ? might try them out as well,
i'd like to be able to run them at 255 at loose timings or around 220 at thighter timings on a A8N-sli from asus. Anyone tested these on this board?
thanks :toast:
I bought them in a store in Aachen, germany.
I'm afraid they won't do 250+Mhz with loose timings, neither of those 1Gb GBNT sticks.
If you wanna run at 250+ speeds, I'd go for the GBHZ kit. They're rated at 250Mhz, 3-4-4-8, and most of them can go higher.
So what's the outcome, what do we think are the chips on NT and NS?
Frankly, I have no idea what might be on the chips.
I'll leave the guessing over to the others. :)
for 2GBNT and 2GBNS we are not talking about 250+ overclock. it is just a value kit :)
i had try like another new batch but the max i can got is around 240
for USD150, you can not find a 2GB kit or 2*1GB will does this big overclock.
Jupiler, could you please take pic of ICs from this perspective:
http://www.xtremesystems.org/forums/...1&d=1133605221
Here's one. Not very clear though.
It's evening right now and lightning isn't that good.
Will take another one during daylight.
http://www.xtremesystems.org/forums/...1&d=1134677014
