Originally Posted by eva2000
The defult volt is 1.275 on my card. but sometimes when i play games the voltage jumps up to 1.375 automatic...very strange.
So what exactly is the exact default voltage on the card? And is ATITool reading the proper voltage for the memory as well on the card? Is it possible that there is a 2D voltage and a 3D voltage?
This is my 05 score with stock CPU speeds. Card was at 690/800
http://i5.photobucket.com/albums/y19...ark05-9265.jpg
Nice job with the clocks!
Now lets see you switch the stock cooler and break 20k 3dmark03 :D
Me local pc-store wil get 1 X1800XT tomorrow and guess who bought it :D Will be a nice weekend!
heheheh, congrats man, GL with the new card!, were all loving our's! :DQuote:
Originally Posted by loc.o
Well things ae looking a bit better for me. After reading a fair lot of posts here on XS, ive pretty much got it nailed now.
using the Tool to oc and set the fan speed, and checking clocks with ATI-tool and changing volts.
Just did an 05 run ar 708/819 actual clocks, i upped the fan speed to 4000RPM, and upped the Vcore to 1.3, got 9881, which iam pretty pleased with, goal is 10k. http://service.futuremark.com/compare?3dm05=1502128
So what is stock volts on these cards then for sure?
I am not sure if anyone knows the actual stock voltage or is 100% sure on what it is. I guess only ATI really knows :p
9972 at 715/828 1.3 Volts. Id did 728 core and it crashed, so seems this is the limit on the core, with these volts, load temps are about 60 odd Cat 75% fan speed, bit scared of using more volts, lol.
http://service.futuremark.com/compare?3dm05=1502264
Nah I used v1.450 and it was fine...just watch your temps is all. Use ATITool and have it save temps to a log so you can go back and see what your high was.
Also what 3rd Party Coolers will work on this card and which would be best for cooling. I want to stay with Air-Cooling. But I would like a better cooler. I know the stock is good but there is always room for improvement.
*If it ain't broke make it even better!* LoL
breaking 20k is pretty easyQuote:
Originally Posted by Shadowmage
http://www.fileshosts.com/DFI/NF4_SL...2_20328_tn.jpg
:D
what CAT drivers you using ugp ?Quote:
Originally Posted by ugp
I haven't touched the mem voltages as bit confused what is for what ? there' s 2 mem voltages
1. MVDDC = core voltage of mem chips
2. MVDDQ = voltage of memory output buffers
when should either or both be increased ?
I just ran through 05 twice at 715/846 and it gave me lower scores than the post above, that had lower memory clocks.
No memory artifacts at 846. :)
EDIT: Even with 722/846 i cannot reach the score i got at 715/828???
I am using v5.11s
I saw someone using some other drivers and I cannot find where to download them at.
I will continue searching for higher clocks when I get home.
Cracked 10k.
http://service.futuremark.com/compare?3dm05=1503596
I think it was done at 730/860. :) 1.365Vcore, 90% fan speed.
Yay :toast:Quote:
Originally Posted by Hicks
How in the world are ppl getting so close to 900 on the mem on air ???!!! :eek: :confused:
Perkam
I was hitting 880 with stock voltage...didn't pursue that any further
900 gave me artifacts but eva2000 said he applied more Core voltage and got artifact free on a clock.
I want to max out my core first.
Thanks for the tip off. Just bought an evga with overnight shipping. MAN I GOT LUCKY. Not saying where i got it i need some time to think if i want to buy one more. MAN IM LUCKY. :banana: :banana:Quote:
Originally Posted by rodman
Called ZFF to cancel my X1800xt + rdx200 order
Congrats there mate :DQuote:
retesting at 2800mhz but higher clocks 742/891
Opteron 146 CAB2E 0540FPMW @10x280HTT = 2800mhz at stock vcore
2x 512MB Gskill PC4400LE @280mhz 2.5-3-3-6 7-14-2222
3dmark05
@621/747 = 9,235
@708/801 = 10,163
@742/891 = 10,795
http://service.futuremark.com/compare?3dm05=1504826
Well 23pts to go :D
And for a treat an original non-resized screenie :)
Opteron 146 @3120mhz
HIS X1800XT @749/891
3Dmark05 = 10,977
http://www.fileshosts.com/DFI/NF4_SL..._2140_2127.jpg
question for stock heatsink are those voltage increases too high or within normal range ?
GPU: 1.45v
VDD: 2.140v
VDDQ: 2.127v
11K in 05 with water!?!?! that's crazy! and based on your Question air on the GPU!
congrats, that's awesome.
i'm on stock heatsink air for X1800XT that's why i ask if volts on card are too high :)
11K nicely done eva. :)
So what's the deal with subzero on the latest retail X1800XT's, are they friendly with it or no, anyone knows?
Ok, never mind, found this: http://www.xtremesystems.org/forums/...ad.php?t=81738, obviously, a more proper place for the discussion ;)
not yet there Dynasty but i will get there just trying some different ram now :)
interesting search on the ORB for X1800 series and 10,977 places me in #5 position :)
http://www.fileshosts.com/DFI/NF4_SL...ks_top6_tn.jpg
Well the question is, what are the temps underload? If its pretty cool I'd say the voltage is good. Whats the amps it uses under that load under ATITool?Quote:
@749/891
GPU idle = 46-47C
GPU load = 58-60C
didn't check the amps have to do that heh
Also, question with X1800XT i tried disabling CCC via service manager and benched 3dmark05 and keep getting 50-90pts lower.. was wondering if CCC's features such as DXT are disabled if CCC is disabled causing lower performance ?
