Definatly. Obviously a lot of guys here are extreme benchers, but for gaming, the XT is the better choice, of course, i never had a 512mb, but i wouldn't want one.
more pics for you folks http://fileshosts.com/videocards/HIS/X1800XT/html/ :DQuote:
Originally Posted by perkam
U had/have both cards, what makes the difference in gameplay in your view?Quote:
Originally Posted by Hicks
I have a x1800xt inc soon... :woot:
Well there's no difference in 'gameplay' obviously, but the XT gets more FPS with better IQ IMO.Quote:
Originally Posted by flopper
Also got a few pics of my Sapphire, with my Digital Camera:
http://img368.imageshack.us/my.php?i...ict02663ei.jpg
http://img348.imageshack.us/my.php?i...ict02679hy.jpg
http://img272.imageshack.us/my.php?i...ict02688jn.jpg
http://img410.imageshack.us/my.php?i...ict02697yw.jpg
http://img124.imageshack.us/my.php?i...ict02708qc.jpg
These cards sure are massive.
I did expect better temps, with the size of the cooler, and all copper.
Well IQ with FPS is what a highend GPU is all about. :slap:Quote:
ah, I did mean herm FPS and IQ...vizzles..
So better FPS, nice...
It be interestingt to see what the new system does for me.
changing to asus ar8 from a neo2 with x800pro.
Its going to be a nice upgrade. :p:Quote:
EVA2000 on your card what is the production part number? It is on the PCB by the HSF and should end with a -20? Does it? (I am kind of taking a pole.....)
Also many here know I am testing X1K CF. I have a tidbit of exciting info I can post. I just got another master card. This one is not a non-qualification sample. (Pre-Production sample that is made in Canada) It is a full production part. For those waiting for Crossfire this is a really good sign..... :woot:
Great news :clap:Quote:
Originally Posted by AACDIRECT
How much will a XL master card cost?
P/N = 102A5200120Quote:
Whatever that means heh
:up:Quote:
If i wanted Crossfire, i assume id need a new PSU as well? That kinda puts me off, heh, as id need new mobo, and PSU.
your OCZ 520w will be just fine for CF :)Quote:
http://img327.imageshack.us/img327/2715/desk3vv.jpg
Stock cooling no mods.
But don't i need another PCI Express connector?Quote:
you can just buy a PCi-E plug, witch normaly comes with the GFX:)
Right ;)Quote:
Originally Posted by macci
ATI has been more efficient than Nvidia with system power in '01 also even though X1800 seems to have lost a little vs. X850. I think a 3.8Ghz FX or a 7+ Ghz P4 would do the trick nicely on fast XT.
Its doin pretty nice in 3D2k1 so far for me. Stock air.
http://img.photobucket.com/albums/v636/loc_oc/44.jpg
I'll tack on a few more points to that ;)
http://img.photobucket.com/albums/v3...789756-910.jpg
Originally Posted by G H Z
is that on stock volts???:)
Nah 1.45v, memory is stock however.
Nice :toast: Goin for 45k tonight.
strange that you can use the 3d clocks. do you have ati smart and hotkey enabled:confused:
Yes, the only thing I changed is disabling the tray add-in. Also I don't know if this has anything to do with it but just prior to this bench I used the ATI Uninstaller for the first time, then re-installed 5.11b's. Setting 3D clocks is nice and seems to me the way it's designed. The screen does not black out like it does with 2D changes.
And I did not install WMD or whatever it's called ;)
