Thanks for the info :)Quote:
Originally Posted by Tony
Can we expect a 706-? bios with more memory voltage options for the DFI NF4?
Or wishful thinking :D
i'm running 704-2BTA on my lp ut sli-dr with X2 3800+ and 2GB ballistix Z503 (in orange slots). is this the best bios for this configuration? will the mem run better in the yellow slots?
thanks.
anyone else using this bios and your optie isnt being reconised correctly on boot up? ive tried 3 differnt bioses and this new one and still no luck :(
peace perc,
I'm using it with a opty 148, no problems...
Perc, I had a beta CPUZ 1.31 and a outdated MaxTcase that gave me the same problems as you with my 175. I re-downloaded both from their respective sites to ensure the latest version and the problems went away.
yeah i cant for the life of me get my bios (no mater what one i use 704-2bt 704-2bta and the latest 11/14 bios) to reconise my cpu as a optie 180 its showing up as a 280 on boot up and as a optie 280 940 pin in cpu-z.... kinda wierd but not effecting performance so screw it i gues.. im getting the expert series anyways so ill just live with it til then...
thx perc,
good
what exactly is the 7/06 BIOS?
What is the difference between the FX60-4 and FX60-5 bioses that DFI has up again?
re: -4 and -5 above, on this link here:
http://www.dfi.com.tw/Support/Downlo...FLAG=B&SITE=US
This files are all the same.. ask DFI, why they wan't to confuse us?! :stick:Quote:
Originally Posted by GravediggA
They are probably just looking at the access logs seeing how many people that download the files have Ultra-D's or SLI-DR's etc
This could be a explenation! :)Quote:
Originally Posted by Gogar
wouldnt sales data do the same?
