Hi, I hope you don't think I haven't tried higher cause believe me I have! The problem is any higher than 1.150 and my screen turns solid black and the computer halts not allowing me to go any higher without a hard reset of the system. I wish I could go higher. The problem I am having is FEAR has those little black squares even at STOCK speeds which should run fine at 1.100 volts. I shouldn't have to go higher to get it to run so I am not sure it is that. It does sound like I need more volts that but tool just isn't working well for me. I really must wait for another program such as ATI tool, Rivatuner, ATI Tray tools etc to hopefully come up with a better way that my card may like to work with when setting volts. The only way I can set clocks higher is with CCC. I set max to 575/550 and use the tool just to up the volts a tad but that is th best I can do for whatever reason. The other thing is this. You say 1.225 to hit 600mhz range on the core but that is also with high RAM speeds to go along with it. I don't think you need 1.225 for 600/550 do you? Perhaps 600/700.Quote:
Originally Posted by mR Yellow
I do appreciate your response though, all the help and ideas you guys have given me is very much appreciated. I'll keep you posted.
BTW my Lost Coast is doing what MANY others is doing and locking up with looping sound, very annoying.
