I wonder if we get any of these tweaks on the Lanparty NF4 Non Expert boards?
Is Oskar still making Bios's for us?
i also want to see crucials as well,thanks :)Quote:
Originally Posted by corvus_corax
Now i can't test crucial as i actually work for OCZ....sorry m8Quote:
Originally Posted by shine121
ill let u know how my crucial ballistix do tomorrow since my expert board will be here
We need some VX action. Maybe some 265 2-2-2-5 runs?? This board looks really good. I might have to save up for this and a nice dual core opty!
When will any OCZ5002048EBPE-K be back in retail? I've got a DFI expert coming on Monday, and no where to buy the ram I want. It looks like it's worth waiting for, but I'll probably have to go with some other 1 GB sticks.
thanks,awaits your results :toast:Quote:
Originally Posted by jetjaguar
We had parts shipped this week...they should be in e-tailers very soon....everyone found out what IC we were using and there was that normal Supply / Demand problem :(Quote:
Originally Posted by 101
what does the Skew do for stability/performance? I know my EB sticks 3D max out at around 268 or so with stock Skew settings at 3-3-2-7 2.7v. If the skew could help me maybe squeeze a few more Mhz out of em id be willing to try it out...
That always seems to spoil the fun when people find out what ICs are being used. Other companies merely wait until you do the work for them to find out what certain modules are capable of.Quote:
Originally Posted by RyderOCZ
Its a shame really.
Eventually, I hope there is a way to secure the modules so that people cannot find out what they are.
Set the bios to Decrease Skew...then try 96, 128, and 192 as values....see if any of them get you higher.Quote:
Originally Posted by Budwise
In A64 tweaker it will say Faster for skew when you are set to Decrease and Slower when you are set to Increase.
OPB has a nice explanation of DQS Skew around here somewhere.
http://www.xtremesystems.org/forums/...highlight=skewQuote:
I tried some of the settings tonight and had some positive results. :up:
Thanks for reviewing the board BigToe :), I wonder wht has happened to WWM, if nothing seroius, is very rude not to come back and post.
I see you have been concentrating on the ram clocking and have been suprised to see no-one mention abt CPU clocking, this board has got new vCore voltage regulation, right??
I hope you can find the time to see if it clocks any of your CPU's higher, as this is one of the main design changes in this board compared to older revision, I would like to know if it is indeed is better.
:fact:
Cheeers
nice results Tony.
BUT it is a pitty that it doesnt do as well as your modded Ultra-D.
So here is the 220 dollar question. Is it worth upgrading from the Ultra-D?
or for that matter is it worth the extra money to get this board over the ultra-d if you dont already have an Ultra-D.
Cant wait for a formal review on the board. Should be intersting to see what the reviewers say about it.
Shamino seems to do fine with the board.
Shamino get FX57 to 3.9ghz without cascade.hihi. Please check at vrzone. I am waitting more.
3.9ghz is with cascade
3.9 3Dmark stable =)
Would I upgrade from my modded ultra D...nope i would not, but not everyone gets boards for free and mods them ;)Quote:
Originally Posted by MaxxxRacer
Now would i spend money on this instead of an ultra D, hard to say as the ultra D has a much cheaper chipset that can still be modded to SLI but obviously voids any warranty. I know the vdimm is better on this board, i still have to test and measure the VTT but I have a feeling this has been improved also. Regarding features it now has true High Def audio which is a good ugrade so this may just sway it for some people.DFI have also moved the 4X PCI slot to a better position so running 3 vid cards should be easier now once you have cut the back put the 4X slot, some who like flight sims will love it for this.
I have run my VX and found it topped out just where it does on my grouper/ halibut/ultra D and every other board i have here which is 267fsb, so it had nothing special to get my UTT clocking that little bit higher. I will post results later for you.
Regarding cpu overclocking I will play with this later, i have water phase and air but i think i will stick to just air for now as I have a better feel for cpu's and if they are doing better.
In response to Maxxxx:
I'm impressed that this thing out of the box with new BIOS etc....... clocks as well as the older mature NF4 boards.
BT:
The audio upgrade is a good point, once I scrounge a few $$$ together I think a couple sticks of 1Gb EB and this board are in my future!
Thanks again BT!
EDIT: here is that skew thread
http://www.xtremesystems.org/forums/...ad.php?t=57925Quote:
thanks for the timely response tony.
but I am in the free board and mods group with you so I think i will stick to my Ultra-d which I made into a carbon copy of your board ;) (minus some secret mods which u said wernt worth my time, despite what my Edsyn says)
The improvement of the Vdimm is a big issue I must admit. Without mods the ultra-D's vdimm situation is nothing short of a travesty. But with the mods it works out very nicely and gives an incredibly stable vtt.
considering 90% of us overclockers are too cheap to get a sound card (me included), the high def audio is a a nice feature. I know that it pains me to listen to the karajan audio all the time with my high end headphones... its just not right.
Thanks for this Tony
Good results with the VX to say your on a first bios and good TCCD clocks.
I may well invest!
Thats if I could I have just been told that the UK distributor isnt getting em in! do you know anything about that?
One thing i have been trying to sort out here is how this board clocks so much better than the RDX200 which is almost the same design from the NB up as the eXpert. Now i know eXpert was delayed, was it delayed while they tweaked it?
I have a feeling we will never know, but I will say i can run cas1.5 on the RDX200 but I can NOT on this eXpert, so something has seriously changed as this was one of the key features Oskar was telling me a while back.
In reality I have a feeling the last ounce of speed has been sapped from DDR1 with this board, i did the same by modifying the Ultra D, the only issue is its like 1% or more at best for most people.The upgraded features on the board do make it a VERY good buy, but I feel running the 2 nV chipsets and dual 16X may have made it a more compelling buy, as it has now been proven there are small gains to be had with dual 16X, and i know most of you here like to extract the absloute max you can from your systems.
Amen to that, let it be the greatest DDR board to come ever :worship:Quote:
Originally Posted by Tony
Good work as usual Tony. Does this new mobo have much love for the low multi folks (a.k.a. cheap bastards) such as myself? Please drop a big divider on it, ratchet down the multi and show us your max HTT. :D
