Question would be: why don't they blow up OCZ, G.Skill or Geil RAM?Quote:
Originally Posted by ben805
Let's do your list:
- Incorrect memory setting: most publish their settings and they look OK. Generally wrong timings tend do fail quickly. Also, this wouldn't explain why so many sticks fail with a delay of a few weeks
- overvolting: I only see reports that higher volts are useless. Unlikely that these people permanently ran chips at high volts when not needed. 2.8 V is what people run them at and what the sticks are rated at
- cheap PSU: certainly not on DFI-Street. They stone you when you come in with something as "crappy" as a Seasonic. It would also be more likely to make the CPU overclock fail, not the RAM.
- insufficient vcore: maybe more likely, but why would the RAM change it's behavior after a few weeks or months?
- active cooling: shouldn't be required (but apparently is)
- faulty mobo: well as I said my Ballistix stick failed in three boards, DFI and Asus. Also, people seem to be fine when they replace the Ballistix with other RAM.
Hate to say but a manufacturing defect is most likely when a lot of people report that sticks bought around the same time now fail at the same time some weeks or months later.
It looks like they go a bad charge of some component on the sticks (not neccessarily the chips themself) that degrade after a couple hundred hours use. Connection to heat is likely.
