Ah! So you were. :hitself:Quote:
pmsl :slapass:Quote:
Originally Posted by Mr. Tinker
However boys, these processors are a tale! Better than the Venice!!!!!!!!!!! :D :D
Also I will soon have him !!!!!!
The OPTERON :toast:
one of our member (OCM) got a 146 and run it into a shuttle , he's able to run OCCT @3Ghz with the shuttle closed , and high temps.
look at his thread : http://www.overclocking-masters.com/...d=36846#p36846
his maxscreen with shuttle and window opened :
http://lagaffe67.free.fr/overclockin...W/cpu-3379.JPG
I want one of those !!!!!!!!!!!!!!!!!!!!!!!!!!! :slobber:
same stepping as mine but wow, does he need 1.6V for 3ghz? mines only got 1.45V
the vcore is not so important, only the final frequency is important ;)
Don't forget it's a shuttle. :rolleyes:
10° less = about -0.15v , so at the same vcore it should have 3.1Ghz @50°c
Try to have 3Ghz rock @ 64° , you'll probably have to give more volts (if it's possible for you)...
the vcore is important, set it too high and run it too long set that high and the chip wont last.
i wouldnt use over 1.5V for 24/7 use and his occt says hes got 1.6V
as for 3ghz rock @ 64C, why? mine loads at 42c with 1.45V so dont need more
i aint having a go or anything, im just saying at them volts most opterons can run stable near that speed
Me too !!!! :banana: :banana:Quote:
and me 1.39v
and it gave this very goog temp under watercooling
http://users.skynet.be/pt1t/146/2005...1-CPUGraph.PNG
:slapass:
Boys, this week-end should have it anchio on the test desk ... ... ... ... ... ... I hope to be able to squeeze it for good! :fact: :fact: :fact:
Hi all.
This question may have already been posed and answered, but once more please help.
I am seeing 2 diffrent versions of Opteron 146
This one is an OEM for $203 OSA146DAA5BN
but This one is box retail and $173. OSA146BNBOX
Both are 939 and same wattage and I think stepping.
Why is the OEM more expensive than the Retail box.
Is this because one is CABYE, and the Other is CABGE, or whatever?
How can you know which one is the right revision or stepping everyone is talking about and one better overclocking than the other?
I am very much interested to buy one of this and your assistance will be much appreciated.
Thanks.
Hi all,
I am new to overclocking and am hoping to get some expert advice here!
I have the following:
-Opteron 146 0540 FPBW
-DFI Lanparty SLI-DR nforce4
-Crucial Ballistix DDR500 RAM
-SI-120
-Panaflo 120mm fan
-Thermaltake Armour case
-Arctic Silver 5
Looking through all of the posts here, I realise I may be doing something wrong. I am currently running:
3Ghz on Air with 1.568V (As stated on CPU-Z) and temperatures:
IDLE : 38degrees
LOAD : 49-53 Degrees
Now in my opinion this is high on load isnt it? Also, I can get into windows and pass SuperPi at much lower voltage (near stock) BUT
There is no way I will pass Prime95. Anywhere between 2mins and 1hour, the test will FAIL.
Have you guys running 3Ghz on low voltage passed prime? Also, can anyone give me any tips as to what changes I should make in my bios, in case that is my problem (as im a newbie with this stuff!). Also, can anyone recommend any other way I can reduce my temps e.g. should I remove the IHS?
Thanks again,
Rixx
