He said a bad word!! :slapass:Quote:
Nope,
Still here. Ive been very busy with everything else. The chiller is where it sat the last time I updated. I will get around to finish this project, just not sure when....
RussC
nooooooooooooooooooooo
...must.. finish.. NOW!!
LOL :clap:Quote:
Yeah. I want to see too. Though id like to build a chiller myself too.
LOL is that second copper coil a desuperheater or what?
if yes i am laughing like hell, damn the use of a desuperheater is WAY LOST
edit:
k i was right, please gimme a break, Good fan on that condensor is good enough. desuperheater is USeless in this system.Quote:
the system redo will have this large desuperheater. I'll put a fan on it also, but thats later
Because ? please explaine.Quote:
Originally Posted by Jort
Nice job :toast:
This :fact: may help explain it for you.Quote:
Originally Posted by mysticmerlin
Lookin good RussC, Keep up the good work.
great job man, i'm building a chiller too. my friends dad is an HVAC guy so he has all the tools i could possibly need.
Ummm, Hello? Is this thing on????
No really is any one here ?Quote:
Did you do anymore or abandoned the project?
Use a private message to ask the question.
Wow thanks for the help on that. :slap:Quote:
Originally Posted by SexyMF
Stow your sarcasm, you have more posts in this thread than the author.
Why are you busting gut to see this project out?
Not to interrupt but I was hoping to see this done as well!! I learn more when I see the end results!! Maybe that is the same way with mystic
Read the whole thread not just ride me. What is the point of this conversation anyway? Did I pi$$ in your cherios this morning or what?Quote:
So rig up your compressor on a board and see how it goes. Then you can build a fancy case and temperature control.
So what was the response from the PM then?
"RussC Last Activity: 05-10-2006 03:11 PM "
But again why is this your pet peave? What did I do to you? Do you know me in another life or what?
I am "doing mine" check out the chilling section of this forum if you can get off my but that long. I am sure you will find something nice to say about it.:stick:
I am done with this, have a nice day and I hope you get a life soon.:exclaim:
Well,
Im starting this back up again. Im dumping the PCV resivoir and am going with the H-50 Evap. Then getting a small resivoir along with it.
I saw the conversation about the de-super heater. That will eventually change into a real cooler from a secound stage water cooler unit. ~1/8W compressor. I plan to run a more exotic referigerant to the pressures should be acceaptable.
Ill have more updates and pics in ~week, still waiting on the H-50 HX. I also have a Pony Pump. It has a stainless steel head, so temps shouldn't matter, and its big enough.
RussC
H-50's are wonderful man, and built to handle about 1/2 ton, plus there solid copper.
Hope it is ok with you SmF that is post in here again.
I build a quickie chiller around one of those HX's and it did -17c in the wide open no ins on it. Can't wait to see what you get out of it.
Well,
I went crazy and pulled out my credit card over at Johnstone Supply......
http://img237.imageshack.us/img237/3935/guageallwc1.jpg
Im going high end now. The system will have the built in guages, a R22 TEV and some real HX's.
http://img237.imageshack.us/img237/7...terexchsg6.jpg
These are 1ton water condensors. But Ill be using them to cool water. The guys over at the DD forum use them in multi-stage systems for condensors. I have 2, so Ill run them in parallel from the TEV.
http://img237.imageshack.us/img237/8379/tevr22ac5.jpg
This is a Parker TEV, R22, -40C unit. Ill be using R22A to start.
http://img237.imageshack.us/img237/9...condns1qx3.jpg
http://img237.imageshack.us/img237/7...wcondnsrk7.jpg
I also got my CC out on Ebay, picked these up for $15 each(got two). That is the deal of the century. There 8"x10"x2". Thell be for the main compressor stage and my second stage.
My second stage will be the inline HX-50(no pic yet). That will cool the refrigerant from the main stage condensor outlet. It just a small 1/8hp water cooler compressor that will run R-134a. That should lower the refrigerant temps by about 10-15C. I figure with R22A, I should get this chiller to ~-45C no load easy.
I also ordered up a leak detector and can tap off of Ebay. Should arrive pretty quick. I looking to get this stuff in the next week and start the build in ~6 or 7 days.
RussC
Looks like my shop floor at work.
Ah! so you're the one I've been bidding against! ;)
I picked up four of those H-50 heat exchangers myself.
Nice work!
