i'll try to repeat my benchmarks with thigher timings later:
http://img497.imageshack.us/img497/901/2801pt.th.jpg
I think i can get it stable with trfc 11 (will not forgot to include a64 tweaker)
PD: That's aircooled.
well my first try with 275+ is here. Not have chance to get 32m going yet. :)
http://img98.imageshack.us/img98/4294/bhddr5506jj.jpg
The same here :)
http://img328.imageshack.us/img328/741/2754zk.th.jpg
275 with tighest timings. I've tried with trfc 11 but it's impossible at any higher than 240.
I see u have changed tref, idle cycle and read preamble, why? should I use that values? :D
Seems that those new values are better. 276Mhz and 0.3 seconds improve in superpi:
http://img336.imageshack.us/img336/7983/2765hi.th.jpg
I'll be in the opty limit soon (still aircooled)
Above 275Mhz it get really hard.. wonder if someone of us will hit 280MHz with this thight timings? :toast:
If i set it to 280MHz with clockgen, i get some wired noises out of my speakers(no sound installed!) and 2 sec later BSOD.. :p:
http://img103.imageshack.us/img103/6895/2751m3os.jpg
Sweet :clap: It's on ;) .......I'm getting my setup prepped for some autocascade action as I'm typing right now......Quote:
Originally Posted by Onepagebook
@Krampak: NIIICE :toast: How much Vdimm does that require and what type of sticks are you using? Time to run some 32m's :D
I'm running at 3.77V, I can't put more voltage without get a BSOD :(
The chips are 0340WF mounted on a pair of mushkin level II.
hmmmm is there a link for that BIOS?
I think it's this one:
http://oskarwu.myweb.hinet.net/dfi/b...s/510-3FIX.zip
I'm using 623-2BTA.
Oh yeah, I remember now :p: I haven't been able to get any runs in lately, but hopefully the time off will allow my sticks to run better just like last time - I had taken them out after they started getting unstable @ 3.66V when I reinstalled them they ran 3.70 perfectly stable with no changes whatsovever. I didn't try any higher, but hopefully I'll be able to run 3.80 this time ;)Quote:
Originally Posted by krampak
Just got my old school bh-5 yesterday, haven't really had much time to play with them but here's what I have so far. :)
http://img46.imageshack.us/img46/7739/2658qa.png
Nice work! What chips are they?Quote:
Originally Posted by TheMeatFrog
Corsair pc3500c2 :) Not sure what the actual ICs are since I haven't taken off the heat spreaders. :toast:
Most likely 313we's :banana: I have a stick right here in front of me that I killed about 2 weeks after buying it when they were still available in retail :rolleyes:Quote:
Here is a pic of them... :) Got them and a 36GB raptor in a sweet combo deal :woot:
http://img366.imageshack.us/img366/7...13520ay.th.jpg
BTW what drive strength and data drive strength are you using and bios?Quote:
Originally Posted by s7e9h3n
It depends on my mood :p: Usually auto/auto works fine for me though ;)Quote:
Just got the autocascade booted with the FX55 and here is my first runs @ TRFC11. The BH5's don't seem to want to go as high as they did @ x11 mult. It's gonna take some more tweaking:
http://img91.imageshack.us/img91/304...mtrfc111oe.jpg
http://img91.imageshack.us/img91/219...mtrfc112ct.jpg
http://img399.imageshack.us/img399/1...mtrfc116zt.jpg
Wow, those are some tight timings. As the cpu gets colder, it cant handle as high of htt. The only thing I can think of (and what I've been trying out) is the DQS thing at the bottom.
http://www.xtremesystems.org/forums/...highlight=skew
It says set to slower for stability and set to faster for performance. Might be worth a try.
Actually IIRC, slower = faster/less stability and faster = slower/more stability :p:Quote:
Originally Posted by moddolicous
Oh almost forgot - this memory can also run a spi1m @ 265 with 3.52 Vdimm. I didn't try for any higher as I just assumed they would crap out, but now I'm beginning to reconsider :p: :
http://img352.imageshack.us/img352/4959/12x2651m6ge.jpg
that's right , from my personal experience, the 12x is the hardest multi. to get over 265 HTT
Heh....when the 0512 FX57 gets here today, I'll just have to run @ 13x265 then.... ;)Quote:
I´m back, changed my winchester for a 146 and it helpt me. I think i cane go higher later. Vdimm 3.68v
http://files.upl.silentwhisper.net/upload5/276mhz.JPG
:D
Played a little bit with the drive srenght, and it seems that i get a little bit better results with it.. more testing tomorrow. :)
http://img209.imageshack.us/img209/2...tight368be.jpg
