Man, wish it was my vapo modded like that! :( That thing is surely a monster. Can't believe you get -42.3 @ 206w. That is SOOO impressive!!! Nice work bro!!!
@ BB mods's:
You did a reaaalllyy nice job with that LS! :)
Keep it up like this! :banana: :D
But... PLEASE can you samurize again what you have done all in all?! :) :D
Would be really nice! :) .... because... the temps are really impressive...
so I think that a lot of people are interessted in this! :)
http://img467.imageshack.us/img467/8...0mprime4hi.gifQuote:
Originally Posted by BB mods's
I am getting +10-12 C :eek: with my stock Vapo LS with Opteron 3150 @ 1.64V under Prime Load runs , is that normal ? :confused: :D Contact with IHS is good , checked and rechecked many times now :confused: What kind of load temps with same settings u think i am looking if i get it moded like that ? :)
WOW... what does vapo display say on temp when doing this? Seems like ambient temp around 22c or so based on PWM temp...?
Perhaps your sensors are not functioning propperly. I don't think it's the vapo.
It depends er1k. X2 tends to heat up cpu way more and will see number like above with X2 running at 1.7v or so. I am wondering if opteron is hotter than X2... (somehow doubtful but could be possibility)
PM NJkid32,Or ill have him post here,them temp's your getting are verry...how u say? not good! The tem's he get's on my mach 2 gtp are verry impressive,them temp's are just uber weak.
BB Mods you can't leave us
*sniffle* noooooooooo *sniffle*
Don't make us kidnap you and force you to continue building phase stuffs!
Here ya go.. Temps at idle and under load and this is with my really hot opty.;)
http://img430.imageshack.us/img430/6...emps2tq.th.jpg
http://img382.imageshack.us/img382/6121/mach17vr.th.jpg
http://img382.imageshack.us/img382/9342/mach22kr.th.jpg
***DAMN, This office PC takes forever to compile this code***
***Hmm... don't think anyone will notice the difference***
***Whirrr...***
***Yeap that's the way to go***
All above are Evap temp , what are the actual CPU temps under load with prime or other heavy load progs ? :)Quote:
Originally Posted by njkid32
~ -40 lol , i think temp sensor from my Vapo is way off :slapass:Quote:
Originally Posted by jinu117
heh , did some testing with S&M Burn in on my Opteron :
2800MHz @ 1.36V - ~ +0-1C Load
3150MHz @ 1.64V - ~ +16-18 Load
3200MHz @ 1.76V - ~ +23 (!!!) :eek: Load.
http://img355.imageshack.us/img355/2804/176v7rm.th.gif
And No LOAD : http://img355.imageshack.us/img355/7...load7vk.th.gif
Rechecked mount again and its awsome . :confused:
BB Mods PM sent :)
no pm yet.
Could be bios related things on this one. -40c prime 95 sounds about right for stock vapo lcd vs the voltage you are running. (bit higher by few more degree than what I expected) What CPU did you have on this before using optie? Might want to do the cmos reset full way, etc if your mobo is DFI. I found out that it somehow behaves different until full reset of mobo when I swap in and out venice and X2.
ok im not happy with the -42*c load temp...i got R-116 comming to richen up the mix i want to see -50 loaded 210w so more testing tomorrow!
BB - sounds like a plan, i'm not going to rush you on this...i have other things to get ready so you take as much time as you need to make this unit shine...
:D
Ah is that the gas? r-116?
PM sent about pricing etc :D
:woot:Quote:
I need such a blend in my dual head unit :p: -50° with 210w is amazing :slobber:
ok guy's got the r-116! @ $200 per LB this stuff is liqued gold..it is simply amazing stuff! load result's friday!!!
Nice Tommy! I cant wait to see this thing in action!Quote:
$200!!!!!!!!! a lb hope its worth it,
It's really cool of you to share these tips, BB :toast: I'll price out some 116 and see what it's running out here in the UK.
It's nice to know which of the higher pressure gasses work well in blends. Looking forward to the final results with it :)
Gray
-50C @ 210W would be sooo awesome, good luck BB :)Quote:
G
Will R116 be a good gas to add to R404/507 to make it colder or handle more load?
At $220 lb it must be really worth it
