Still no matter what I do I cant get past 190 fsb. :( O well atleast it let me change the multi's. :)
hey sminker what cold boot problems r u talking about?
i have had mine up for months and never had one. By the way i am close to kc mo also! lol:)
My friend has this same board and upgraded the to the newest bios. He was able to unlock his xp1700. He could change the multipliers just fine and what not. His cpu is not a tbred. Found this pretty interesting.
Originally posted by MickeyMouse
I haven't checked does the new bios show DDR voltage in the HW monitor window??
No it doesnt :(
Im really surprised you havent heard about it. Check out the AMDMB forums. Its been talked about there. And i also get it whenever i OC over 170FSB.Quote:
That was the main reason i bought my 8RDA+.
What part near KC do you live in?
Im out here in Lees Summit.
I just did back to back memory bandiwdth tests using sandra2003. The only thing I changed between tests was the multiplier.
at 215 X 10X I got 3326 / 3124
at 215 X 9.5X I got 3203 / 2981
My system gets really funky at 2-2-2-6 using the twinmos at much over 220mhz. I'm going to go put the twinmos back where it used to be, in my dedicated folding@home rigs. They've been down since yesterday...Quote:
Originally posted by Pjotr
You should be able to run the TwinMOS in CAS2-2-2-6 or so. I'm running my TwinMOS chip ones at 200 MHz 2-2-2-5 at the moment.
TwinMOS generally tops out in the 220s. At least with CAS2 setting.Quote:
Look a Caper...Quote:
http://www.xtremesystems.org/forums/...7256#post87256
Seems like the links not working, can anyone post the files here ?
What do u guys unlocked, FSB limit of 211 (which is now 250), or perhaps the fixed multiplier (which you cannot lower, 13 is fixed)?
Because I flashed the BIOS from E to 1002 beta 1, and it didn't do anything for me, exept allowing bigger FSB, which is pretty worthless, if you are stuck on a multiplier of 13. :brick:
if you are not unlocked, then just use the wire in the socket posted in the other thread. took me 5 mins start to finish to do it
Yes, but I see no info on the timings, so I don't think it runs CAS2 there...Quote:
I believe that was run at 6,2,2,2
I could be mistaken though.
208.81 7-2-2 cas2 rock stable in second config with 2*Corsair PC3200 cas2
VDDR@2.8v
Here's 2 X 512Mb Mushkin PC3000 running bios 1002 @225Fsb ;)
http://www.cox-internet.com/kjy13/im...51dcddrmem.jpg
Your score seems a little low for that FSB. Heres my 8RDA+ at 225
http://home.kc.rr.com/sminker/images/sandra225.jpg
guys can you please send me bios 102 beta 001, asus link doesn't have it no more, thanx
nunez1980@hotmail.com:)
I just sent it to you. The zip is about 375K...Oh crap...I just saw you wanted non-deluxe...sorry I send wrong one. Lemme see if I have the non-deluxe too. If so, I'll send it.
