What do the temps say on your mach? Cuz mine say -54c under load but windows will say 0c or -1c and we all know thats not correct.;)
raiden I already said it ;)Quote:
Originally Posted by Raiden Zero
"(temps on occt aren't correct but the differences between the temps is allright!)"
and improvements without HS now:
"first time I ever passed OCCT @3070MHZ @1.65V today"
and additionally running prime 3044MHZ @1.65V now instead of 1.7V and with better RAM timings. see if it will hold it this night.
AND FINALLY JOINED THE 26s CLUB :toast: :
http://www.casextreme.net/pixx/bench...210_26s_1m.jpg
(I could improve RAM timings because of better temps, but I think the board is at the very end...increasing chipset voltage up to +0.2V won't bring any stability...32m runs @3150MHZ @1.7V but Prime and OCCT will still crash within 10s)
The real temps I'm really not sure...but maybe too cold....not even 1MHZ higher Pi (but 322HTT is near board end :/ )
-45°C display temp unload is ~-55°C measured (veryfied with ice-water) (OCCT shows ~-90)
some idle temps:
1.4V-1.55V display ~-45/-44°C (OCCT ~-89/88)
1.65V display ~-43°C (OCCT ~-87/86)
1.7/1.75V display ~-42°C (OCCT ~-86)
When I had air-cooling on it OCCT showed ~-19°C ^^
I think the run is over now...board maxed, maybe a 3.3GHZ S.S. but not this week...I had enough for the moment...1 week is over...0:30 after midnight again - WTF? didn't remarked that until this moment....time to get some sleep...good n9...
...Greetz SoF
€dit: 2:30 o'clock in the morning here, again only 6 hours left before I have to work again...BUT THIS IS CRAZY!!!
Prime @3044MHZ @1.65V was running fine and I finally decided to sleep...my 24/7 rig and the compressor immediatly shut down with a slight *boom* I first didn't realized because I almost felt asleep until the compressor beeped as hell (as it always does because it's not connected with the board) I JUMPED up, last night was hard enough, had 3-4 hours to sleep after HS cut off and testing, so I was very confused, turned off the compressor, looked for water, then I realized the server was down as well :stick: Wouldn't turn on until I disconnected it totally from energy...but I will not turn on the compressor tonight because I want to let it de-freeze. There where some minutes compressor was running and CPU was off...I don't think it's good...no prime tonight because of a stupid ****** causing a short circuit in the house...if this continues I will jump out of flat (you think ~10m are enough? *lol*)
but now: GOOD night.....
hi sof :) nice nice . i think ill take this crappy hs away ^^. but youve 2 beat my 25 sec :) if you read this message plaese turn on icq, ive a question :)
ok i will do so ;)
after one day I always can tighten the screws a little bit more...now load temps are again 3-4°C better...but after the failed prime yesterday the machine has to warm up again with a prime run :( I have the best ram timings for Pi now and they will be ok in stability as well ^^ so what I will do now is to burn in the processor on these high ram timings and see if I can pass 1m @3250MHZ (should give ~26.5s)...without new ram 25s is definitly impossible.
Greetz SoF
that's atleast 25..maybe 25,6 or 25,8 :DQuote:
Originally Posted by SoF
anyway try with a fresh win2k3 server :)
better to run spi 1mb there even without tweaks
well I was running the 1m @3200MHZ and the RAM isn't that good for PI.
There are several timings I can't tighten without reboot or freeze.
Therefore the 3200MHZ gave me the 26.9s and 50MHZ should give maximum improvment of 0.5s (not sure if my RAM could handle this with 166er divider).
Greetz SoF
yeah thats correct. i´m using the entreprsie edtion an with an x2 @ 3 ghz its amazing :D
Hi,
were I live we say "felle haas" to people who go in something xtreme :p (it means xtreem rabbit)
so, FELLE HAAS :)
thank god the heatsink got good off, otherwise, what a waste.
primed this night on 3060MHZ and had a Pi 1m @3220MHZ @26.938s BUT I wanted to save the shot and *REBOOT*
never got it again yesterday :(
but I'm satisfied. Will be off for 3 days going back in the real life to my family and girl friend...I could pass on this but my girl would kill me if I would stay another weekend 200km away from her *lol*
Will do some optical stuph in 2 weeks going for the best looking compressor cooled system *hhr*
Cheers
SoF
:D just replied in your topic
crossposting :nono:
BUT: :slobber: :slobber: :slobber: :slobber:
:toast: :woot: :toast:
AWESOME!
but whats acutally the super pi record 4 a 3000+ ?
ask for it in the PI section I have no idea but you must be really close to it!
