I'd really like to hear about those 8rda+ wpcredit tweaks. Anything yet to fix the under 10 mulitplier issue killing mem bandwidth?
man opp thats crazy! 3ghz is not far off!
I ran into some problems, my radeon doesn't want to Overclock at 220 and up. I can do maybe 5 tests before a blue screen or reboot, its the Radeon Overclock doing it. I have to figuer somthing out because I'm getting some outradgeosly high runs, if I could only make it through :D
OPP
Opp, COOL THOSE MOSFETS!! 8-)
What chip was it, exactly, that blew at 1.95v or whatever it was for that guy? Maybe some cooling for it might help? If its that hot at that speed, it must be hot at lower speeds, too?
EDIT
Would better cooling of the power regulation area of the R9700 Pro help? Theres already cooling on it, but its just a plate.. 8-/
Nice Job As usual...Quote:
OPP
But OPP...
That does not make sense... The AGP Buss is locked, and the FSB should not affect the card. Is that not right?
Maybe try manually selecting 66MHz...
RoydRage
I believe it was the lack on the 5V line, very weak. I turned it up but now my 12V is running like 13V :D Oh well. The card is clocking well at 219. Here's a tease, the next one will be for my buddy DJ :D
EPOS POWER
Go OPP, GO!
:toast: :toast: :banana: :banana: :toast: :toast:
DDTUNG:cool:
I spy a spelling error! 8-)
man am I bored.. 8-/
EDIT
Someone donate Opp a non-crippled 9700pro 8-)
oh yeah, baby! GO OPP GO!!!
omg.. its been 20 mins and opp hasnt made a new post..
!!! 8-)
The suspense is killing me, lol 8-)
EDIT
20.. darn clock on puter is 8 mins slow.. 8-)
Give her hell my friend:thumbsup:
Looking like you'll be taking your friend down very easily indeed..along wth your own latest Intel score:toast:
Onwards and upwards !!
Randi:D
Hehe, I noticed that he just un-published his previous AMD score from the ORB, just as I went to look at the details. Must be something better going up...:D
Absolutely fantastic work OPP!!! :toast: :toast: :toast: GO! GO!
i just put the NF7 back up :DQuote:
For some odd reason the Orb won't let me publish these new Epox benches. I have to find out whats going on.
OPP
Holy ****.
Damn what a score. :thumbsup:
The ORB wont publish it? Others have had the same issue, I think it sees your FSB speed and determines it to be a fake. Remember awhile back when they wouldn't allow 4 GHz Intel scores?
I wonder if there are errors being introduced at these clock speeds?
But if there were, that wouldnt make sense, because the P4 would do it, too..
You should take a set of PSU's and wire them together, opp 8-)
AAAAAAARRRRGGGHHH!!!!!Quote:
OPP
The suspense is killing me! :D
I know there's a thread in here somewhere about problems at the Orb publishing high FSB scores on Epox boards...anyone seen what I'm remebering and know where to read about it? Thought I saw something where someone had a workaround...time to start searching...
Holy Testical Tuesday!!!!
Check it out, it is reporting the wrong clock speed. The Active one was just done at 2859Mhz and the first one was done at 13mhz less. I guess the orb or the mobo will need a fix if we are going to put the Epox on top :D All you Epox Gurus need to ask mad Oinion what the problem is with my scores. I have to keep going while I'm on a roll:D
OPP
Well even though it doesnt say so on the orb lookin at that you are #4 in the world and you have a AMD!!!!!!!!!
CONGRATS!
Wasn't the fix, to save the file then go to submit file and select the saved file?
Too bad that 23k one isnt at 1024, lol 8-)
3Dmark has a hard time reading CPU speeds for some reason...
Take a look at my thing.. its detected as like 1.6 and im actually running 1.66... 8-/
EDIT
Yeah, try "submit saved result"... I always do it that way and have never had a problem yet..
EDIT 2
It shows correctly on the orb.. 8-/ Not in 3DMark2k1, though..
EDIT 3
I cant get on there either.. checking again right now.. no workies.. 8-(
Is this the thread you mean? Don't see any fix in there. :(Quote:
*edit* There is a link in that thread to another on the Futuremark forum, but I can't seem to get onto any part of their site except the ORB. :confused:
could the orb being down have somthing to do with this
MrLavender...that was one of the threads...but I also seem to recall, now that Nico mentions it, that the supposed fix was to save and then submit, but it looks like OPP has already saved, but just can't submit.Quote:
Unless OPP tried to submit it first, couldn't, and then saved it, and needs to try resubmitting now that he's saved it!
OPP, have you tried submitting after you saved?
EDIT: See my next post for a somewhat better statement of all this :rolleyes:
