Nice results so far can't wait for some 3D. :toast:
off topic, Did you make that skull? because it's the coolest thing I've ever seen
No I bought it. It's made of some kind of resin.Quote:
Originally Posted by DragonOrta
No. It's that same 780es I made all the 3d runs with. The newer cpuz reports it correctly now. I would love to get my hands on a retail 780m.Quote:
Originally Posted by MickeyMouse
The tube sings :slobber: Sounds like you have tuning forks int the base, the expansion rates even if they where only a few millimeters long and relatively thin would make them vibrate, so I'm thinking lots of thin pins??
Regards
John.
The hissing happens between -165c and -190c. Even with the dothan, if I let the container go dry for abit and then hit it with some ln2, it hisses like mad. Louder than anything I have ever used for ln2, it's pretty wild. I can keep my temps at any temperature I want from 0c to -190c with ease.Quote:
Originally Posted by pythagoras
I am almost done testing the design's effectiveness, and I will show it soon. I am confident now that this thing flat out rocks with ln2 for controlling temps, as it was intended and it does equally as well with DI too.
My "Ice Dragon" is making this fx scream..total control..how far will she go?
http://pic8.picturetrail.com/VOL256/.../112899923.jpg
http://pic8.picturetrail.com/VOL256/.../112899928.jpg
K|ngp|n,
If you ever run 32M with that setup then you will be the most versatile and complete top bencher on this planet:
AC/WC/Phase/DI/LN2 and 1M/8M/32M/Pifast/Aquamark/3DMark :shock:
After you're done reclaiming all 3D spots, finish off with some 32M :) That would be just surreal :D
BTW, sweet container! Waiting for more pics :clap:
WTG very nice results! :toast: Now it's time for you to hunt for a new card to make up for the lacking one. :)
Thanx J & HB
Thank you bach, I worked hard on the container, and it is paying off.Quote:
Originally Posted by bachus_anonym
#1 SLI is within reach, even though Shamino is making nearly impossible.
heh..as for 32m. I have kinda stayed away from it for fear of losing hardware, but maybe I will give it a go when I am done with 3d and some updated 1m and 8m. Didnt OPB lose an fx during a 32m run?
Don't understand why 32m would cause you to loose it. Wasn't his w/ the hole blown in the socket? Must have been due to not enough dielectric grease or too much voltage IMO. :) Don't think it'll die if evrything is set up right. Although I am NOT one to be commenting on condensation problems lol. ;)Quote:
Edit: NM was thinkin of the 55 w/ the hole in the socket.
Maybe I said it wrong dude :)Quote:
Originally Posted by harleybro
It is more of a question of "do I really want to burn up a good piece of hardware running a benchmark I am really not that interested in"?
But for you die hard 32m guys, I will run it when I wrap up my fx/sli benching in a day or two here, hows that? Whats the 32m record btw?
Thanx man :) OPB and denny both have got some serious mem speed working for them there on that one.Quote:
I remeber now, my chip that I got from you is the one ranked at #7 there isn't it ;)?
Killer FX speeds..
Nice Going KP!
KP
common, show us how it looks inside!
or give some general info about it +)
^^^^if you had the best bench cooling device ever built do you think you would share?
kingpin you and shamino should hook up i bet with your cpu overclock skills and his GPU overlclocking skills you guys would take down 18k in 05.:)
he won't, he put too mutch work into it.
remember asetek and baker block;)
Wait where's this ranking table? :confused: Understand whatcha mean with the 32m. Really lookin forward to what you pull off in 1M and 8M. :)Quote:
I remeber now, my chip that I got from you is the one ranked at #7 there isn't it ?
http://holicho.lib.net/pi3355/pi3355.htmQuote:
There harley. Jason posted it above.
If i can get the cpu working right at 3840 with the 14x at these timings and bus speed that I ran here below, the scores will be pretty nice :)
ABout the best im getting out of these mushkins:
http://pic8.picturetrail.com/VOL256/.../113132450.jpg
WHere I am atm with cpu power:
http://pic8.picturetrail.com/VOL256/.../113144112.jpg
16x isnt necessary for these cpu mhz btw
Aha thanks KP. :toast: Lookin good so far if you get those clocks w/ the 14 multi it will be killer. I may give another go soon but lookin forward to gettin bk into the 3d world lol. :)
well... for some reason I doubt DI/LN2 will ever go even remotely mainstream, but i understand what you're saying. the xtreme cooling arena is just much too cutthroat these days.Quote:
Originally Posted by Jort
awesome results, good luck with your aim to hit 3840 with the 14x at those timings and bus speed, i recon you can do it :D
Time for some xtreme bling bling. We saw how it kicked the fx's ass at di temps, now we will see the true power of my container and what it was actually designed for. It is VERY arc friendly.
http://pic8.picturetrail.com/VOL256/.../113653376.jpg
780es at almost -190c idle in windows at 3900mhz+ with 1.85v on the processor!! Again these are the best idle temps I have ever gotten, and a personal record. Especially considering where the processor clocks/volts are.
http://pic8.picturetrail.com/VOL256/.../113653385.jpg
This shot was taken after pouring about a quarter cup of ln2 in the pot with container base temps at -165c. In almost a blink of an eye after pouring, my temps jump back to -189 and the container roars loudly. It's incredible.
http://pic8.picturetrail.com/VOL256/.../113653382.jpg
These pi times can be much better, and hopefully will be with some work on this worn out p4p800 I am using for testing. This thread is about the container and how it performs with different chips and loads first and foremost, everything else is secondary. I used this motherboard because I am able to give the chip over 1.85v without issue from ovp/ocp.
With the usual tweaks of dram lat par 11, 200fsb boot, and maxmem 104 this 1m is prolly around
19.5 - 19.6 seconds. Definitely not at the chips limit mhz wise either.
Picture was snapped right as benchmark ended:
http://pic8.picturetrail.com/VOL256/.../113653396.jpg
How about .2 -.3c load temps rise during 8m with a 780es at close to 1.9v and 3900mhz+? :slobber:
I was so floored when I ran this bench, I had to run it three more times to make sure it was for real, and it did it flawlessly all three times:
http://pic8.picturetrail.com/VOL256/.../113653392.jpg
http://pic8.picturetrail.com/VOL256/.../113653942.jpg
Again, the time isn't all that really and could be hugely better with the above mentioned tweaks and some tighter timings. I tweaked nothing here. This is just to show what the container can do with the pentium M close to it's limits mhz/volts wise. I want to see how far I can push the chip mhz first, then I will start tweaking and tuning to get the times down.
http://pic8.picturetrail.com/VOL256/.../113654657.jpg
I'll be posting more pentium M stuff soon...
That container is unreal :)
Wow Kingpin remeber when we couldn't bench FX'es towards 4 ghz and now it is dothan.
awsome mate.
You have to begin benching for WR now
