nice chip :clap:
nice chip :clap:
Not Super Fast but OK :)
http://www.forumdeluxx.de/gallery/da...3170MHZ-WC.JPG
Good job mate, pick up a decent power supply and you should get more
whoa what a monster :toast:
That CPU pwns my Opteron 146!! :slobber:
Really nice OC, now boost the voltage up and let us see some more screenies! :D
woah, nice sd you got there... go for the wr! :D
ps: endlich malnen bisschen deutsche oc-action hier!! :D
:slobber:
incredible cpu ,only under water ! but what's your watercooling setup ?
did you tried it on aircooling ?
Mora 2 Pro with 9x 120mm SX1 7V !!
Nexxxos XP CPU Cooler
Laing DDC-Pumpe 12V Pro
Cape Coolplex 50 extern
Tygon R3603 11,2/8mm
Only Cpu Cooled !!
Not tryed on Air !!
Those are some really cold idle temps! Looks to be about online with some of the better Opties, very nice!
Originally Posted by STONKA
Hehe , that's a big setup , good job.
got pics of your cooling ? :eek:
Nice Clocks Here .
Did You measured the 12v with multimeter? , what was the result finally ?
ite SmartGuardian Said 11.96 5.05 & 3.2
My multimeter said ---> 12.16 5.08 & 3.33~3.34
On my Enermax 600w
Not measured but i have big problems 3170MHZ is prime95 6H and superpi32M Stable about 3180MHZ is not stable with 1.56V become Bluescreen in prime95 and superpi32M and 12V is than under 11.54 whren i push the Vcore at 1.58V !
pics i would be make toomorow of WC !!
Bleh, what a bad chip only 3170MHz Prime stable... :eek:Quote:
Looks like the first sign of instability is a bluescreen on these latest AMD chips.
I can run SuperPi 1M at 3148MHz without an error but when i click 1MHz Htt higher with ClockGen and try 1M it just bluescreens.
Awesome chip btw mister :up:
My Opty is the same way Zeus....BSOD or bust.
