Its only a net gain of 1VM :( Adding 4 was too much for a gig of ram to cope with, 4VM's @ 180 ish MB each, + all the associated servies etc.
Not given a huge boost, but a boost all the same :D
Might add another to this machine if you're adding more though ;)
Do u have a tweaked version of XP?? If u do, then u might be able to use 4. I gave my vm on one comp 64mb ram, and I think right now it uses only ~50mb or so.
Hrm could probably hack it down a bit...
6 agents on the 1 connection is ~ the max I'm willing to run tbh, might try and squeeze another on this machine maybe.
Gonna get a VM setup on the machine at home, which gives 2 clients on that machine, trying to get another setup on a mates pc too...
Its a pain the connection is shared tbh, otherwise I'd have loads more cilents running
Use nlite. Download it from nliteos.com. U can get rid of windows components u dont need (ie paint, drivers u dont need, and alot of other stuff) and disable any services u dont need. It works great. Both of my VM's only use ~700mb hard drive space and ~ 50mb's of ram. Works great.
Hrm nice :D Will have a play and get another OS installed on this machine
Cheers dude :D
Fedora core 7 has a nice built in featureset for running VM's
