Originally Posted by MrSeanKon
FE4R you should give me more info:
1) What's your mainboard?
2) What's your cooling?
3) What Vcore you are thinking for permanent usage?
You did OK cos in the past your CPU passed Prime95 at 2.4GHz with Vcore=1.35.
But don't use ZZZ at this moment cos you are running near to previous MSF I mean 2420 - 2400 (the previous MSF) is not great difference....
Also be careful with priority don't set Above Normal or High Priority right now...
Find first how far you are CPU Stretcher stable (ZZZ=0, Normal Priority, Threads=1) and then if you want to go higher set ZZZ=20 - 50 and Lowest Priority...
Run this program at least for 6 hours per day but as you saw my recommendations don't run it for many hours!
You must relax your CPU for some hours! :)
