cool man!
how much is a 1hp rotary more or less than a regular hermetic
edited
cool man!
edited
They are all hermetic. Hermetic is a fancy word for sealed.The black outer shell that the compressor is in makes it hermetic.
You're benching 3D at -107...
:clap: :clap: :clap: :clap: :woot:
That's a nice piece of work, Kayl :slobber:
What kind of heatload you figure it's running at approximately?
Running it at 10-15" loaded is pretty amazing, but -107 under load is just fantastic. Well impressed!
Gray
OKay, that rocks :woot: well done ;)
awesome kayl... love the cpu evap mounting :D
Hes referring to a reciprocator compressor i believe.Quote:
Originally Posted by wdrzal
thats not load its idle going into load.Quote:
Originally Posted by Gray Mole
I still need to add insultoin now.
Was benhing it tonight heavy over and over and its falling under -100c.
I had a large fan blowing on the compressors tonight and this section here need insulation now especially the 1/4 as that the 1150 liquid line.
but that will have to wait awhile ME all out $$ for a while.
http://www.xtremesystems.org/forums/...id=37788&stc=1
ouch what happened there ?
Yup, a little more insulation will probably improve temps a little.
Considering the best 2 stage cascades out there generally bench under -100c you're doing quite well with it. I'm sure a little more tweaking will make all the difference. Any exposed frost is stealing your coling power, so more insulation and more until it's all hidden :)
Gray
It is the HX out. He insulated it with "great stuff", and burnt it with his torch while brazing i guess. No big deal ;)Quote:
Originally Posted by eva2000
yep as slacker said thats the capillary end for second stage.Quote:
i had to change capillary line to fit this evap.
Still waiting on more copper to try differnt round evap.
thanxs garry, ya reminding me or garry (original we all know :toast: )
ya any good at water chillers :stick:
i think insulation second stage and ill get -100c.
I had it benching prime today -100c for 20mins. top of second stage compressor hit 78c. Have to watch those temps they get friggen hot.
It was 28c in the shed at lunch, got to get ready for summer. :woot:
so with insulation ill get -100c which is my aim prime for an hour pority 10. I havnt seen anyone do that yet.
cool temps man,
we are just getting done with summer temps are finally bearable.
Hah don't you just love internationality?
I am getting ready for winter. Damn cold. My hands were all blue when i got to school on my bike this morning. I am definitelyt NOT built for that. I am better in 50c ;)
I like that cascade. rotaries makes for some nice temps :toast:
grass is always greener on the other side!
lol
Might be.. I don't complain. I love snow, if it wasn't so damn cold. Anyways it's all about clothing ;)
If it gets too cold i'll just go to work. At least i can always have my 40+ C there :D
But hey, India is pretty hot too. You probably haven't even seen snow.
Can't you do anything to the compressors? Adding refrigerant wont even help i guess..
India has almost all types of climate, i am in delhi winters min are 2-8C at night,
summers go up to 45*C, Min max for today are 34C and 24C, it snows allot in the north, it rains allot in the east and south. man we are getting of-topic.
yeah the slacker i have only ever seen snow when i went to europe for holiday.
slacker the roataries jun normal 70c and close to 100c. i think garry or some one said they can handle as much as 110c.
I know runmc used mesh wire on his compressors as heat sinks.
I just use a fan blowing cool air over them seems to keep them under 100c
the new guy we get similar temps.
today i was driving around for work and look what i come across jusrt sitting in rubish bin along with other crap.
ehehehe heaven on earth. cascade insulation city.
SO later that night after work i jump in the car and picked up this.
http://www.xtremesystems.org/forums/...id=38141&stc=1
heheeh i dont know where to keep it all, the wife is gonna cut sick when she see it all.
Time to start benching prime.
It will run for 1hour here it goes. :toast:
http://www.xtremesystems.org/forums/...id=38142&stc=1
I was just checking mobo its been holding 10mins now -99.7.
i found condensation is just pooling everywhere damit.
so i added paper tissues to soak it all up and insulate.
http://www.xtremesystems.org/forums/...id=38143&stc=1
http://www.xtremesystems.org/forums/...id=38144&stc=1
ok it crashed once but its finally finished.
cascade has been on since 9:30pm now till 1200am.
almost time to switch off.
this is prime for an hour, its slowly getting colder the longer i leave it.
and prime straigh after.
evap -100.5c
1st stage out -48.7c
liquid line 1150 out -46.7c
suction line 1150 before compressor -22.7c
http://www.xtremesystems.org/forums/...id=38162&stc=1
http://www.xtremesystems.org/forums/...id=38163&stc=1
http://www.xtremesystems.org/forums/...id=38164&stc=1
Time to break out nail coating.
Have you considered a conformal coating like Phil mentions in the third to last post here http://www.xtremesystems.org/forums/...ad.php?t=75095 ?
yes noob i think i might have to extend that nail posih a little.
imdying yes conformal coating works quiet well. i did my epox socket A mobo a while back.
when i get a NF4 mobo ill look at doing that one conformal coating.
the nail polish can be removed though thats why i went for that this time.
Yeah, normally they can't tell if you've overclocked something to death... conformal coating is a bit of a give away... no RMA for you!! :D
amazing man!!
