Utt-bh5
:) As this is my first post here I suppose it's acceptible that my scores with this stuff and nf2 be lowest. I strongly suspect a part of the reason is a weak psu.
I tested w/2 diffrent boards. Asus a7n8x-e deluxe. At T1 and T2. And my DFI Ultra Infinity at t1 only. Both boards maxed stable T1@210mhz's Asus @2-3-2-11. UI 11-2-2-2-2-13-15. The UI would boot and run@230T1 but crash when I opened an app. The Asus would boot-loop @220 T1. The Asus @T2 I was able to get a single stick semi stable @217.(Each stick would error 32meg superpi's at about the same place) Still 210 dual channel is about the best I could do with that @T2. With the asus. My stick's were "OCZ el ddr pc 3500 gold gx dual ch".UTT-BH5(Savin' those for nf4 or sumptin' else) It's not the memory's fault. It just doesn't seem to like nf2. + I need a psu upgrade. I now running ocz pc4000 goldvx This works much better! :banana: Hehee........ I don't feel bad that 210 was the best i could do with it. Still I've seen others do much worse. I've found some of Uwackme's post's between here and the bleedingedge and dfi-street. So I've picked my power supply. OCZ Powerstream 520 sli ready.(Hopefully that'll work) Hehee "Clay"
Update
I thought I'd update this thread as I've had a minor break through with the UTT-BH5 and nf2. 225fsb T1 11-2.0-2-2-2-2-9-14,Alpha's 3-3-5-3-2-2-3 Dr-str's and slews auto. Better psu helped better timings help too.(OCZ el ddr pc3500 gold gx)
1 Attachment(s)
Well, my setup:
Abit AN7 Enduracell's an718de82T bios
2x512 OCZ Gold GX 3500 (new BH5).
Stable 235@3.05V@2-2-2-9-2T
With 1T bios i cannot pass 201-202 fsb.
I have used other double sided sticks Transcend 2x512 with jedec PCB
that managed @227@2.5-3-3-7-1T@3.2V.
So NF2 can manage 512 double sided sticks with 1T for high fsb
For OCZ the other timings are:
