Thanks Rub :)Quote:
Originally Posted by Rub87
Vtt is specified to need a maximum of 3amps iirc, so almost any small power MOSFET should be ok for a Vtt regulator and it souldn't need a heatsink. I don't know if the motherboards Vtt supply will like having an extra voltage put across it, as with the Vdimm supply and the booster, but I don't see why it wouldn't work. Putting the Vtt supply on the booster would mean that you would have to mod your board tho, which people might not want to do. I'll look into that :)
I was thinking about using the unused 1/2 of the LM358 for OVP, but I didn't think that it would be necessary.
@ b|lly
Thats a good idea. Is there enough space around the Dimm slots for an active cooler?
