I've had my mobo up to 370HTT fully stable, which means I could get 3.3GHz out of a 9x multiplier chip... Since my CPU can't do much more than 2.8GHz I don't feel too limited at the moment :)Quote:
can you try 1:1 9x300
awesome overclock!
but would anyone venture to get why this new revision? e3 -> e6?
aren't e6 reserved for dual core chips? are these possibly rejected dual core chips with one core disabled?
any guesses or speculations?
A new PSU is not in my budget. Feel free to donate ;).Quote:
Originally Posted by Vincentvega18
As to the 3000+s being limited by the HTT, i find that's hardly the case, unless you're going well above 3 Ghz with phase change HTT should not be a limiting factor.
I think I am going to pick up one next week.Hopefully from ewiz
Who knows that stores online are sending the E6 in USA at this moment?
How can we check if we're using 704? I updated my bios a while back but I dont remember the number.Quote:
Originally Posted by smids
i think i got the same chip? damm i just sold it too :( oh well wont be the the first good chip ive gotten rid of....
peace perc,
Originally Posted by DamienKC
Use Everest --> Motherboard --> BIOS. U can see ur Main BIOS and VGA BIOS.
Are there any E6 rev chips for San Diego cores?
I'm still trying to figure out what the rev E6 is... I thought E6 was dual core. :confused:
E6 to my understanding is an improved core based on the current stuff which runs at 1.35V stock. It's also labeled on the IHS 1.35V.
I run at 1.28 stock :)
But then again, its just my mobo being weird
I still am not convinced that these new ones overclock any better than E3s.
It's just the heat output. Lower voltage rating means lower heat output, means higher potential for stable overclock. Just like how mobile chips tend to clock better than desktop stuff.
Socket 939 E6 Stepping :
ADA3800DAA4BW
ADA3500DAA4BW
ADA3200DAA4BW
ADA3000DAA4BW
Sempron Socket 754 E6 Stepping :
SDA3400AIO3BX
SDA3300AIO2BX
SDA3100AIO3BX
SDA3000AIO2BX
SDA2800AIO3BX
SDA2600AIO2BX
SDA2500AIO3BX
That sound good :x
Maybe not what the old E3's were doing(week 16-19) but seems far better than the newer E3's so far.Quote:
Ewiz clearly lists product numbers. They show BW and BP steppings... Ewiz has 3000+ with E6 stepping definitely.Quote:
Originally Posted by LANero
TrueQuote:
Originally Posted by Doom5
Someone should order from Ewiz to confirm they're handing out E6s at 118$ a pop.
Ohhh Good
Thanks for all Friends
just ordered 2 3000+ BW's from eWiz!!! can't wait
i will post the steppings on here when they come
So all S939 E6 are currently only for Venice?
i got mine from a kid who bought it from e-wiz so yeah try e-wiz thats where this E6 came from...
peace.
also bought one from ewiz...will post results on tuesday (or whenever it gets here).
k I have 510-2 by Hellfire. is that ok?
3000+ BW headed my way from ewiz also :)
