I would guess that they fall under general, but again. test them all to see what one works best for youQuote:
Originally Posted by Vapor
jjcom
jjcom
When in doubt just use -3 :D
for micron chips the 3,16 ram table workin best for meQuote:
Originally Posted by jjcom
Does it really matter which one you use as most of us set the timings manually after a flash anyway...?
702-2 works great for my Mushkin Redline....better than any other bioses out there :D :D
How hard can it be to simply make this bios work with a PS2 mouse withou having to plug a PS2 keyboard in at the same time? I really am loosing patience with the DFI guys about this. :( :(
otherwise after a flash, needed to reset cmos to get the board to boot and all is fine now except that nagging usb mouse thing. :slapass:
I think so, yeah...Quote:
Originally Posted by Huigie
Anyway, is it normal to NOT be able to use the yellow slots at all with Micron/Ballistix? No post, nothing. Currently using -3 (not sure which table that one has....?).
EDIT: if memory serves me right, -2 is actually the 3/16 table and -3 does have a problem with the yellow slots or something, right?
-1,-2,-3 work with both yellow and orange.Quote:
Damn my DFI just died :( I'll try this one after i got my board back from RMA
-3 most definitely does not work with yellow for me. Could be my Ballistix though.Quote:
Originally Posted by pershoot
-1 works for me best out off all finally my ram is stable at 312 and beyond... :toast: be4 it wouldnt run even 308 stable ...
tried the 702-3, Im still no closer to get 1T to work, not even at stock :(
with 2x512mb?!? :eek:Quote:
Originally Posted by ffletchs
yeah, ever since I got my venice 1T has been real hard to get working.Quote:
Originally Posted by stealth17
Dont know if my memory controller is fubar or if it has a coldbug :confused:
Hopefuly Oskar will come out with a new series of Bios that can 'unlock' the CPU multiplier becoz I am using winnie 3000+ and the highest multiplier is only 9. How I wish I can get 9.5 or 10 or 11 or anyting higher so that I do not need to oc my RAM to its limit.
I think that limit is imposed by the silicon, not the bios.
lol loke stu said, its cpu not bios. why cant you just run like 300htt? and then a divider of course ;)Quote:
Originally Posted by longsiew
http://www.lejabeach.com/DFI/dfinf4ultra/704-2BT.zip
Lastest BETA Bios:
Date Code 2005/07/06
File 704-2BT.zip
Size 390,190 bytes
Description:
Mod by BigToe
1. Removed all the CAS settings that don't work.
2. Remove the added 0.1vdimm thats applied when you set TRCD to 2
3. Add Ram Option A, B, C, E, D; support for ddr533 with FX57.
Flashed and running fine :)Quote:
Originally Posted by Gnux
Hmmm thats about the best bios I have used up till now with my TCCD :confused:Quote:
http://img306.imageshack.us/img306/3881/pi128008cl.jpg
i did not have chance to test these bios. is a good ?Quote:
Originally Posted by TheMeatFrog
i excpecting my mobo!
I just flashed to 702 -2 and now nothing boots :(
My computer restarts right after it begins loading windows. :slapass:
Anyone offer some help on how to boot, i loaded optimized defaults.
Unplug your psu.. then press the power button a few times to discharge any power left in the system..Quote:
Originally Posted by AMD-me
Then move cmos jumper to the clear position and take the battery out for 10-15 mins..
After the 10-15 mins put battery back in and move jumper to normal position.
Put power back into psu..
Boot up..
OK, I just flashed -3 on my Ultra-D with my 4200. I am definitely getting faster and more stable overclocks in the early going PLUS this bios fixed a problem I was having with memory bandwidth testing just totally sucking on my x2 proc. Not very definitive at this point, glad to post results as they become more final, but the x2 is getting back up over 2.6 on air and I ain't done for the day.
Nice to hear ugly (if I may call you such :) ) please keep us posted as I and I am sure many others are very interested in how things go for you :toast:
