yes you are right, the real clock is 500/1400. before i can't get good score with manual overclock 500/1400. With victor's BIOS, i can.
:D :toast:Quote:
Originally Posted by Benny Lodewijk
which one you use?
too many version outside...... :p:
7800A1OC-2d-500-1400-without Thermal monitoring.ROM. Please check your PM victor. :D...
here's the other results :
3DMARK 2001SE :http://service.futuremark.com/compare?2k1=8632410
3DMARK 2003 : http://service.futuremark.com/compare?2k3=4080882
So does this defo work then?
i mean will they be fixing it in a driver release or should i go ahead and flash the card?
yeah id also like to know that
Thx Victor.
Yes it worked \o/
1st run on 05 gave me 8570 core 495 mem 1300
x2 4400 stock .
im gonna have to go trawl through the DFI thred now to learn the tricks and tips for overl:banana::banana::banana::banana:ing that.
hopefully Nvidia will sort this out soon as id prefer to be able to keep a eye on the temps.
Try new 80.** drivers for dual core to see if u get an higher score
Originally Posted by marius7
yes please do that !!!
@victorshen
The last 2 Bios works very good
THX
Greetings
No_Name
I've trying the new forceware, but for single 7800GTX, 77.72 is the best for now. The score is decreasing when i'm using 80.40.Quote:
The 80.40 Forceware is worse points in the 3 Dmark2001 2000 like the Forceware 77.72
Both drivers are identical in the Aquamark of the performance
hi all
i am running air cooling on my asus 7800
here is my result.
2005 8470
http://service.futuremark.com/compare?3dm05=987530
2003 18791
http://service.futuremark.com/compare?2k3=4085094
stock asus bios
77.50 drivers ?Quote:
Originally Posted by DEVIL_DK
watercooled XFX
http://service.futuremark.com/compare?3dm05=987930
reports my core as 551 ( i wish ) my speeds are 510/1350
Cpu= X2 4400 @ 2640mhz
Dynasty
no 80.40 driver
I tried my cards with the latest modded bios under DI @ -70C. Works fine. Sorry to say that the mobo fried my FX-55 before i got around to make some fine points though :( Sitting and waiting for an FX-57 to arrive.
you used this bios? 7800A10C-noPB-noHM-470-1300.rom?Quote:
Originally Posted by Kinc
Is your X2 also watercooled? Those clocks seem lowish all the way around...my X2 and 7800GTX do pretty much those clocks on stock cooling (actually, my 7800 can do 520+/1430 on stock cooling, just gotta publish those on Tuesday).Quote:
Originally Posted by Usurper
Have you tried pushing any harder? I'd like to know what I can expect once my watercooling is finished.
Well i havent pushed to hard at the moment, i dont know what the safest max core for the X2 4400 is, i have moved to 250fsb x10.5 ( 1.55 core) now giving me 2.63ghz, 2.71 wasnt happy at 1.55.
as for the 7800, i am not comfortable pushing too hard when i cannot see temps, id imagine they are ok but its the not knowing. TBH i think you are lucky on air with the clocks on your 7800, 520/1430.
I have seen a few reports of other people on water who cannot get past 495.
Looks like nvidia are going to release a new driver that removes the throttling this week according to evga rep.
Regards
Andy
WOuld be nice to see my temps again.
on another note i can bench at 526/1380 (highest the "test changes" on the properties will will me do , anyway around this?) or should i try riva tuner?
i knocked it back to 515/1350 for 24/7 running, as i thought i saw artis on BF2.
I can se my temps with the modded bios on my XFX cards.Quote:
YeahQuote:
Originally Posted by GoriLLakoS
Questions.
Is the bios you mention 1.5v? ( ignore me i see its 1.4 )
Kinc,thanks :) Ill try the above
Should i overclock via rivatuner? and if so anything i should change amend in settings?
BTW when i use coolbits reg to get overclocking options, card doesnt pass 500/1400 in test :(
but passes 525/1380 .
