cracks the 5k barrier with OCZ PC3500 PLAT LE BH-5 :D
PCmark05 = 5,009
http://service.futuremark.com/compare?pcm05=21327
http://www.fileshosts.com/DFI/NF4_SL...10_5009_tn.jpg
PCmark05 = 5,009
Here's my updated score: 5136 (broke 5k with mild overclocking) :p:
SamHughe
Originally Posted by eva2000
Yeah, A64 can't really compete with multi-threaded cpus (overall score)
I get only 4657 at 2.9Ghz 2.5-3-3-6 and raid 0
http://service.futuremark.com/compare?pcm05=24695
i cant see anything... anyone got a link to a fix???Quote:
Originally Posted by [Cipher]
6534 (X2 4400+ @ 2820Mhz)
http://service.futuremark.com/compare?pcm05=12734
i agree. i am able to run at the settings in my sig all day. 3dmark 03 and 05, AM3, PCmark04, sandra, all right after the other stable as can be. looking back though, 3DMark05 did the same thing to me until they came out with the patch. hopefully a revision of some sort will fix the weird problem :slap:Quote:
Originally Posted by Peen
New Score:14183
http://service.futuremark.com/compare?pcm05=28449
Rig: 3,2 Xtreme Edition 840, 2x7800GTX, RAID 0 and.... Gigabyte i-RAM
It is a valid result, although the RAM Drive gives EXTREME FAST numbers.
extreme fast... damn thats twice as fast as the next highest score... infact its higher then 04 highest score
ramdisks are :cool: :D
4733
P4 570J Abit Fatal1ty AA8XE XFX 6800U/512MB
http://service.futuremark.com/compare?pcm05=25487
AMD Athlon XP 2800 and FX5200
Ramdisks are amazing can I ask where you bought that from or was it given to you for a reviewQuote:
Originally Posted by dimcar
Got it for review... Not yet available in the market.
About the iRam, what memory are you running on it ? PC3200 ? I've seen that Gigabyte updated his specs to support 8Gb, is this right ?
Does it run SATA II ? Otherwise you'd need quite a lot of those drives to get more than 1GB/S through put.Quote:
If it's not SATAII how have you configured it ?
Ι think he is using software....not hardware.....:)
Originally Posted by GoriLLakoS
Well the Gigabyte iRAM IS hardware. But the score seems a bit high for SATA.
If it doesnt use sata II there would be a major bottleneck so I would say it should support sata II
It's just that in the specifications that have been made public nothing has been mentioned about SATA II support.
But I agree it seems stupid to make a drive like that and not make it SATA II
Sorry for the misleading post.... I just got confused between many scores of iRam and soft ramdrive and having a job in the same time.... :confused:Quote:
Originally Posted by Kristian
This result IS with a soft ramdrive.. iRam is scoring lower...
Sorry again and Kristian sorry for not replying to your mail but i had TOO muck work today and a lot of meetings...
That's ok. Which program are you using to make the ram disk ?
QSoft ramdisk
Oh please... :rolleyes:Quote:
Originally Posted by agenda2005
nice 7200+Quote:
are you sure about that one ;)
