Before wdrzal tried it I would have said low. People who have a micron gauge don't use compressors to vacume a system, and people who use a compressor as a vacume don't own a micron gauge.Quote:
What are the chances of someone testing a pair of compressors on a system with a micron guage?
I'm not too keen on the idea of putting a glass bottle on the high side of the pump, but I was thinking of putting volume marks on the bottle and measuring the rate of evaporation.Quote:
Then by trying to remove just a few drops of water fro the bottle on the other side of system.
As far as figuring out how much of a vacume my pump can pull, I was thinking of trying to boil water at lower temperatures. At 20 degrees the pressure needs to be lowered to 2.339 kPa, which my pump was able to do. At 0.01 degrees the pressure must go down to 0.6113 kPa, or about 4600 microns. If my junkyard compressors can do that, I will be thoroughly impressed.
Here's a question though, why do you need to pull such a deep vacume? I understand the need to evaporate the water from a system and remove most of the gases, but why do you need to pull the vacume so deep? At what pressure/temperature would the compressor oil start to evaporate?
