Hi,
CBID Final Version 7.50 already out, check at cbid.amdclub.ru, i can enable AMD 64 Architecture and Hyper-Threading but i can't verify this feature enable or not.
Hi,
Originally Posted by thedi
Just got the final, but theres no way to push any new buttons.
Edit: I found It but cpuZ tells me its not enabled. Lets see Everest home.
Anyway, you can disable mmx and others, and they go disabled.
Doesnt work :(
He..he..you can try with AthlonXP and they work?, i can enable everything,Quote:
Originally Posted by Esmein
and wcpuid verified.
64 virtualazation is a nogo for me :( says i can't enable it
Not working for me either.
Hmm--
--Anyway, these s754 64-bit semprons look promising. Maybe I will buy one as a spare proccy/OC with it.
Wonder if the tool will only work on more recent Semprons?
jjcom
I tried 64 bit extension on my 2600+ s754 sempy, and no success.Quote:
I think this only works on Rev E Semprons. :(
It looks like it would only work on recent steppings, doesn't it? E3 core at least it seems.
i thought the semprons were going to be released today... i cant find them anywhere.
so, generaly this is a big dissapointment? :(
You mean CBiD ? Not at all.Quote:
Originally Posted by Nedjo
